Ome suspention
pieterpotgieter
Full Name: pieter jacobus johannes stephannes potgieter
Nickname: Piet verf
Home Town: piet retief
Current 4x4: nissan 4.8
Home Language: afrikaans
Ome suspention
Post by pieterpotgieter »
Hi I want to fit ome coils what weight class do I go with front and back
Re: Ome suspention
That depends entirely on how heavy you load your vehicle.
The harder the load rating, the less the suspension sags when you load it, but the bumpier and less comfortable the ride is when loaded less than maximum.
Grant
Full Name: Francis
Nickname: Grant
Home Town: Rosendal
Hilux 2,4 4x4 SC Dakar
Been thanked: 26 times
Re: Ome suspention
Post by Grant »
Pieter,
I have had both OME and TJM on my Troll. I opted for the medium on the front and HD on the rear, as I have a considerable weight, with drawer system, fridge etc permanently fitted. I now have TJM fitted and although they are extreme travel set up I am very happy.
Call Herman at 012 653 8834 LA Sport.
Re: Ome suspention
I have the medium OME on my Patrol and it is very comfortable!
pieterpotgieter
Nickname: Piet verf
Re: Ome suspention
Ek sleep karavaan en het dakrak so ek laai die meeste van die tyd, sal 200kg voor een 400kg agter reg wees
Grant
Full Name: Francis
Nickname: Grant
Home Town: Rosendal
Re: Ome suspention
Post by Grant »
Pieter,
Another option is to fit air suspension into the rear coils. This helps enormously with he sag and stability when towing. You can then opt for the 200 kg front and rear, so when you are not towing or loaded you still have a comfortable ride. When you hook up the caravan, you inflate the bellows on the air spring system. Lift the rear of the vehicle and gives you added stability.
http://www.assc.co.za/leisure-air-springs.htm
