Aircon Drain
Aircon Drain
We just came back from the Botswana Outreach and I found that the floor on the leftside is completely wet - even on the door side of the rear seat.
We had to drive with the aircon on all the time because of the heat (34-37 deg) and what I noticed was the rear aircon part did drip water when you are parked but not the front part dripped.
I checked the drain at the firewall and found the pipe sticking through the firewall but there is no rubber pipe connected to it and no seal between the pipe and the firewall so I think that because of this the water is leaking back into the Patrol.
Is there supposed to be a rubber pipe - with a 90deg angle - connected the the drain pipe?
I'm now trying to dry the carpets!
Grootseun
Full Name: Driko Henningse
Nickname: Grootseun
Re: Aircon Drain
Post by Grootseun »
Kobus ja sover ek onthou is daar n pyp daar , sal vanmiddag op myne gaan loer en n foto neem indien sigbaar
2001 9.4 Patrol DI GRX
Bigger Intercooler
Oil Catch Can
PC Bash Plates
More Mods to follow
Re: Aircon Drain
Baie dankie!
