Alternator Bearings
Chris Skinner
Full Name: Chris Skinner
Nickname: Chris
Has thanked: 10 times
Been thanked: 53 times
Alternator Bearings
Post by Chris Skinner »
I have now sorted out the major source of rough sounding engine - it was the aircon belt tensioner pulley bearing.
A very easy 20 min DIY job with a R20 bearing from Midas, thanks to the advice of Andries and Grootseun in my last post on this matter.
When originally trying to identify the source of the noise I also noticed a lesser second source comming from my alternator front bearing and while in the mood I think I will also have these bearings replaced - can this be a DIY?
Removing the Alt is simple, but what about opening and replacing bearings??
Does anyone have any advice on this, or better to take to a professional.
David
Full Name: David Prinsloo
Nickname: David
Home Town: Stellenbosch
Been thanked: 49 times
Re: Alternator Bearings
Post by David »
Chris, glad you got it sorted :clap:
I posted under the Patrol reference the various belt sizes and part numbers you required earlier. The v-belt can definitely be sourced from somebody other than Nissan but I don't know about the other belts? Let us know the part numbers if you used non-genuine spares :thumbup:
Grootseun
Full Name: Driko Henningse
Nickname: Grootseun
Post by Grootseun »
Chris which alternator have you got on there - if its the bosch if yes its an easy job as follows
Pull it off , take of the regulator first so you dont brake the brushes when you split it in two by loosening 4 bolts , leave the stator and diodes intact , clamp the rotor gently in a vice and renove the nut that holds the pulley ( if its a clutch pulley youll need a special tool )
Now press the rotor out and carefull not to brake the drive end bracket , use a bearing seperator to pull the rear bearing off , if memory serves me youre gonna need a 6303 and 6201 bearing , replace and reassemble
If it the Hitachi alternator - similar process but the regulator is build in so no need to remove , youll need the bearings as samples there though as Hitachi takes non standard bearings ( bearing specilist dont even bother with midas ) - just be carefull when you reassemble , theres a small hole in the back bracket stick a thin hard wire throught that and past the brushes to lolck them in place so you dont brake them off when putting the two halves together
Hope this helps , if you struggle give me a shout its not rocket science but needs some patience and knowledge does help
2001 9.4 Patrol DI GRX
Bigger Intercooler
Oil Catch Can
PC Bash Plates
More Mods to follow
Chris Skinner
Nickname: Chris
Great, thanks for the advice, will try it during the week!
Grootseun
Nickname: Grootseun
Post by Grootseun »
Chris see youre also in Centurion , if you battle pop around ive got the tools and ill assist you to change the bearings out , no problem
Bigger Intercooler
Oil Catch Can
PC Bash Plates
More Mods to follow
Chris Skinner
Nickname: Chris
Thanks for the offer Grootseun, sounds like a plan for a needed free alternator lesson 101. I will start the job and see how I go but chances I will get back to you...
Grootseun
Nickname: Grootseun
Post by Grootseun »
Anytime Chris
If you get stuck give me a shout i can give a lot of lessons for a glass of coke
Bigger Intercooler
Oil Catch Can
PC Bash Plates
More Mods to follow
Chris Skinner
Nickname: Chris
Grootseun, I got the thing out and stripped, no problem, but getting the bearings off is a bit more of a challenge without right tools.
Brute force will probably result in some unnecessay secondary damage...
Can I bring it over to you sometime in next day or so.
Send me your number in a PM and I will call you.
