Rear windscreen wiper help required
Full Name: Julius
Nickname: Jules
Current 4x4: Pathfinder
GQ Patrol
Home Language: AFR
Has thanked: 94 times
Been thanked: 76 times
Post by Jules »
Has anybody with a GQ had any problems with rear windscreen wiper? Mine has stopped working a while ago, I have checked the fuse is still fine, neither the water nor the wiper is working. Where would be the first place to check for some life.
also the main electrical window console by the driver for my window works perfectly everytime and then on the other sometimes not, but I can at the individual doors operate the windows. Are there any parts there that one can clean to improve contact ? Why when I open or close the other windows from my console do the window moves very slowely, when I use the switch at the actual door it moves more rapidly.
Grootseun
Full Name: Driko Henningse
Nickname: Grootseun
Re: Rear windscreen wiper help required
Post by Grootseun »
Hi Jules , quite new to the Patrol scene but as an Auto Lec by trade id say you have some arced conctacts in the main window switch , can be cleaned but be careful they tend to come apart easilly bit not go back together so easilly
Have had rear wiper issues on scimilar vehicles and almost always found the wires to be broken of where they go from the body into the door as the door gets used a lot and wires dont like flexing that much - unsure though if the patrols run through in the same fashion , only get ours tom so i cant even go and check for you
Just my 2 cents worth
2001 9.4 Patrol DI GRX
Bigger Intercooler
Oil Catch Can
PC Bash Plates
More Mods to follow
Been thanked: 1038 times
Jules there is a solenoid in the door, in front of the switches. Clean this and the window switches with switch cleaner or alcohol, maybe it works. As Driko said, be carefull when dismantling switches. Partucularly on our old cars, the plastick becomes brittle, but if you do open the switches, a little bit of ghrease on the contacts might also work marvels.
When I got my car the rear windscreen wiper did not work, and it turned out to be the switch.
Ek dink jy gaan maar vir jou 'n multimeter moet koop en begin vroetel?
Full Name: Julius
Nickname: Jules
GQ Patrol
Home Language: AFR
Post by Jules »
Tanks Gents, any particular Multimeter, hopefully there is an instruction booklet in the box else I might just blow up my lorrie.
Peter the solenoid you are talking about is that in my door?
Yes Jules, in the driver's door above the speaker.
My recommendation for a multimeter is to try and get one whith a clamp that can measure DC current, as this helps a lot in monitoring dual battery system charging issues. I have a Mojortech MT777, which is very nice. This particular multimeter also has a temperature probe which can measure up to I think 1000C.
Grant
Full Name: Francis
Nickname: Grant
Home Town: Rosendal
Hilux 2,4 4x4 SC Dakar
Been thanked: 26 times
Post by Grant »
Jules,
Bou a laai systeem in, sit a yskas in, en bobs your uncle. No need to fix the wiper, because you can not see through their anyway. Good excuse to convince SWAMBO that you need a reverse camera.
:blonde: :blonde: :blonde: :blonde: :blonde:
Full Name: Julius
Nickname: Jules
GQ Patrol
Home Language: AFR
Post by Jules »
Grant I like the way you think!!! :woo:
I must just convince Koos Best now to assist me in putting together a drawer sistem and slide for my fridge.
Grant
Full Name: Francis
Nickname: Grant
Home Town: Rosendal
Post by Grant »
Great,
Jammer ons het nie meer gesels op die 60 GTG. Before you decided what you want, go onto the internet and google drawer systems. Below is an example. After you have decided that is it, call SWAMBO because see has to agree. Good Luck
http://www.google.co.za/search?hl=en&sa ... 5.4.2l19l0
