Standard Y60 rear coil springs
- Been thanked: 1036 times
Does anybody have a set of Y60 (GQ) patrol rear coils lying around?
I have a friend who wants to see if they can be used on a Hyundai Terracan, which some say is very closely based on the S2 Pajero.
PC
PC
- Grant
- Full Name: Francis
- Nickname: Grant
- Home Town: Rosendal
- Has thanked: 3 times
- Been thanked: 26 times
Re: Standard Y60 rear coil springs
Peter,
Call Herman at LA Sport Centurion - 012 653 8834. They might have some.
- Gerrit Loubser
- Full Name: Gerrit Loubser
- Nickname: Gerrit Loubser
- Home Town: Richards Bay
- Current 4x4: None
- Been thanked: 11 times
Peter, I am afraid that I am going to rain on your mate's parade.
There is a bit of Pajero Gen 2 DNA in the Terror-Can, but unfortunately the rear suspension is very different on the two. The 'Can uses rear coil springs that are quite a bit smaller (104 mm vs. 145 mm, I think) in outside diameter than the Pajero (or Patrol), so it won't quite be a plug-and-play effort.
Thanks Gerrit
That saves us quite a bit of trouble.
PC
PC
Hmmm - that sounds a bit like the TERRANO springs size ??? miskien kan jy daai een naspeur P/ter?
- Gerrit Loubser
- Current 4x4: None
Mac, you are not far wrong. The Terrano springs are indeed around 106 mm diameter, but as far as I know the wire diameter used in those Terrano rear coils is of a significantly lighter gauge than that used in the Terracan coils while the free lengths are similar, so I think you would have reduced ride height in a 'Can with Terrano coils. Then you just need 20" bling rims to complete the lookKagiso II wrote:Hmmm - that sounds a bit like the TERRANO springs size ??? miskien kan jy daai een naspeur P/ter?
Gerrit Loubser wrote:Mac, you are not far wrong. The Terrano springs are indeed around 106 mm diameter, but as far as I know the wire diameter used in those Terrano rear coils is of a significantly lighter gauge than that used in the Terracan coils while the free lengths are similar, so I think you would have reduced ride height in a 'Can with Terrano coils. Then you just need 20" bling rims to complete the look
Thanks GerritObelix wrote:Ek het. Bel my 0836524012
Gerrit OosthuizenEk het. Bel my 0836524012
Gerrit Oosthuizen
