CAHNGE AUTO TRANSMISSION OIL- PATROL 4.8..2006
Suliman
Full Name: Suliman
Nickname: Sal
Home Town: Saudia Arabia
Current 4x4: Patrol Safari 2006 Auto 4.8
Post by Suliman »
Hi ..everybody...I just registered in this forum and i found it informative.
My car is Nissan partol 2006, 4.8 petrol engine with Auto Transmission. it has 130000 Km
I have couple of questions.
when the Transmission oil should be changed? I do not have the owner manual and when I search the net I have found people saying : there is no need to change the oil since it is not like other auto transmission..all you need is to check the level of the oil and add only Matic -J oil if needed.
others say that transmission should be change only after 200,000 KM....I am real confused. please advise.
when I went to the repair shop for Transmission oil change , he told me that he will change only 4 liter. which means he will partly change the oil since the transmission has 11 liters on it. I search the net and I found way to flush the entire transmission oil through the cooling radiator hose. the below youtube link explains ..please check it.
Do you think that this way can be used with Nissan partol 4.8 Auto Transmission?....have you ever flush Auto transmission oil? please share you experience.
I appreciate you help.
David
Full Name: David Prinsloo
Nickname: David
Home Town: Stellenbosch
Been thanked: 49 times
Re: CAHNGE AUTO TRANSMISSION OIL- PATROL 4.8..2006
Post by David »
Check out 'StrayCat's post on how to change the oil: http://www.patrol4x4.com/forum/nissan-p ... ial-15547/
