Max Ellery Nissan Patrol 1998-2009 Manual Special Offer
cullendw
Full Name: Daniel Cullender
Nickname: Daniel
Current 4x4: 2001 4.5l Nissan Patrol
Home Language: english
Post by cullendw »
Hi,
I managed to finally find an excellent Max Ellery workshop manual for my 2001 4.5l Patrol. This manual covers Patrol models from 1998 to 2009 and contains everything from changing the oil to rebuilding the transmission.
I found this gem from Motorbooks (http://www.motorbooks.co.za) which can be found at The Colony Centre in Craighall Park. I had a chat with Dewal Basson and he said that he would be happy to give a 10% discount if you belong to this forum. He can be contacted on 0861 113 947 / 083 441 3237
I have uploaded an image of the front cover
workshop manual reduced.jpg (80.98 KiB) Viewed 3721 times
Daniel Cullender
Chris Skinner
Full Name: Chris Skinner
Nickname: Chris
Has thanked: 10 times
Been thanked: 53 times
Re: Max Ellery Nissan Patrol 1998-2009 Manual Special Offer
Post by Chris Skinner »
Hi Daniel
It is very handy but I found that you need to be pretty advanced technician/mechanic to use it effectively - way above my level. For example, for engine and drivetrain repairs I found there was insufficient detail on how to get to the problem in the first place ie the step by step to remove and install something - it seems to focus on how to repair the item rather, once everything is dismantled.
cullendw
Nickname: Daniel
Post by cullendw »
Hi Chris,
After going through the more advanced sections in detail, I agree with your comment! (I am an amateur mechanic at best). I found the parts on maintenance and servicing detailed enough, but, as you mentioned, the more advanced stuff is lacking in detail
Daniel Cullender
Chris Skinner
Nickname: Chris
Yes, but probably worth having though, anyway!
David
Full Name: David Prinsloo
Nickname: David
Home Town: Stellenbosch
Been thanked: 49 times
Post by David »
Worthwhile but lacking. :thumbdown: Compared to my Haynes manual (for a differnt vehicle) I prefer the Haynes.
Also found a lack on detail for the 4.8. - Engine & gearbox wise it is ok but there is basically nothing when looking for the 4.8's handbrake which is basically a drum brake inside the rear disk brake.
I tend to make use of a combination of MaxEllery & electronic workshop manual when tackling any maintenance.
At least it is better than nothing :thumbup:
Chris Skinner
Nickname: Chris
Where can I source that electronic w/s manual??
David
Nickname: David
Post by David »
I have downloaded it sometime ago from the internet but can't remember exactly where :think:
You can try: http://www.filestube.com/e9e8f5ffb04d4b ... l-Y61.html - It is about 140 MB
If it doesn't work I can put it on a CD and mail it to you :salute:
Chris Skinner
Nickname: Chris
Thanks David, a cd would be great, it will take me forever to download 140meg with my connection!!
Will you be at 3Provinces? If not pse post would be good.
David
Nickname: David
Post by David »
No - I will be attending the Atlantis party. PM me your address and I will do so :salute:
Russ Kellermann
Full Name: Russell Kellermann
Nickname: Russell Kellermann
2005 Patrol 4.2TD Wagon
Post by Russ Kellermann »
I have the Max Ellery and i love it, but i do agree that Haynes manuel has slightly more detail on pulling/fitting parts. Still, amazing book and well worth the purchase.
