Gearbox Oil change
Krippel6
Junior Member
Junior Member
Full Name: Riaan Annandale
Nickname: Riaan
Home Town: Sandton
Current 4x4: '99 GL 4.2D
Gearbox Oil change
Post by Krippel6 »
Hi guys,
I just wanted to mention quickly what a difference changing my gearbox oil has made - I did it just over a week ago, I put in that GL4 castrol - forget what it's called. But yah, it took just over 3 liters of that stuff, and is now smooth as silk.
Yesterday I did a decent length trip (towed 2 bikes to redstar from honeydew) and the 4th gear doesn't even scratch anymore - I am VERY impressed, and am even more confident that the patrol will last forever!!!
Re: Gearbox Oil change
:thumbup: :thumbup:
Full Name: Gerrit Loubser
Nickname: Gerrit Loubser
Home Town: Richards Bay
Current 4x4: None
Been thanked: 11 times
Post by Gerrit Loubser »
Krippel6 wrote:I just wanted to mention quickly what a difference changing my gearbox oil has made - I did it just over a week ago, I put in that GL4 castrol - forget what it's called. But yah, it took just over 3 liters of that stuff, and is now smooth as silk.
I assume you used the Castrol BOT 130 M as recommended to you by Peter Connan (in this post)?
Krippel6
Junior Member
Junior Member
Nickname: Riaan
Home Town: Sandton
Post by Krippel6 »
That's the stuff! -
Sorry, it's Monday morning and I'm full of Sinus - the brain also needs some BOT 130 :P
Chris Skinner
Full Name: Chris Skinner
Nickname: Chris
Has thanked: 10 times
Been thanked: 53 times
Post by Chris Skinner »
Can this oil also be used in the 4.5 petrol - I cant imagine the gearboxes are that different....or what?
Adrianjvr
Full Name: Adrian
Nickname: Adrian
Current 4x4: '91 SWB Patrol 4.2d
Post by Adrianjvr »
Chris, I tried the Castrol BOT 130M for a couple of weeks, but changed back to an EP90 oil about two weeks ago. The gear rattle on the td42 is a lot noisier with the 75w90 synthetic oil.
Traveler
Full Name: Heinrich Stoltz
Nickname: Traveler
Home Town: Springs
Current 4x4: Patrol 3.0 GL,
Post by Traveler »
On how many km's is it advisable to change the gearbox oil?
I'd consider doing it anyway since the odo is reading 120k km.
Marino4x4
Full Name: Marinus Potgieter
Nickname: Marino4x4
Home Town: Bloemfontein
Current 4x4: Nissan Patrol
Has thanked: 17 times
Been thanked: 87 times
Post by Marino4x4 »
Hi Traveler
I see the service manual says every 80 000 Km or 48 months.
You can check if the condition of the oil through the filler plug on the side of the gearbox. Open it and stick your finger in. The level should be 5mm below the opening and it should be nice and clear. Do not know if the previous owner did it so it might be good to check first.
Good luck.
Patrol 4.5 GL 1998
Terrain 4X4 Parts
I did mine a few weeks back with EP 90. What a difference !! If for preservation of the g/box.... then anytime is a good time to do a change!!
Traveler
Nickname: Traveler
Home Town: Springs
Post by Traveler »
Then it will become priority. :salute:
