Faulty Central Locking Actuator (Apparently)
Full Name: Gerrit Loubser
Nickname: Gerrit Loubser
Home Town: Richards Bay
Current 4x4: None
Been thanked: 11 times
Post by Gerrit Loubser »
The central locking in the passenger side front door on Imvubu seems to be faulty. When locking or unlocking the vehicle using the remote control or the master switch on the driver side door, the front door actuator emits a kind of ticking/growling noise and tries to move the lock linkage, but does not succeed in moving it far enough to actually lock the door.
I have removed the door trim and sealing plastic and all the linkages seem to be OK. I have tried to lubricate the linkages, but this has made no difference. I assume that there are delicate bits of linkage in the actuator that might be worn/jammed so my next step would be to remove the actuator and see about taking it apart.
Has anyone perhaps done this? Any ideas?
Re: Faulty Central Locking Actuator (Apparetnly)
Gerrit, myne het ook so 'n probleem gehad!
Ek het toe die swart boksie [vir die remote ontvanger] agter die panel langs die petrol petaal uitgehaal en van die kontakte se soldering het gesmelt - hoekom weet ek nie! Ek het dit net oor gesoldeer en toe werk alles reg.
Eenkeer het ek ook 'n probleem gehad dat as jy die remote knoppie druk kom die liggies op die dashbord ook nie aan nie en jy kan nie die Patrol start nie - klap toe daai panel toe werk die liggies. Dit was ook dieselfde probleem en moes die kontakte oor soldeer.
Hoekom dit brand weet ek nie!
ChristoSlang
Nickname: ChristoSlang
Home Town: Pretoria, ZA
Has thanked: 27 times
Been thanked: 136 times
Re: Faulty Central Locking Actuator (Apparently)
Post by ChristoSlang »
If it is the actuator, get a set of three actuators (and one sender) from AutoStyle for R150. Or spend R250 and get four actuators (the "remote" kit)...
Christo (the snake man)
Current 4x4: None
I removed the actuator (bit of a fiddly job requiring something like an offset Philips screw driver or just a very short stumpy one) and cleaned it as well as the linkage properly. Everything was very dusty and grimy. The actuator seemed to work OK outside the door. I refitted everything and now it all works as it should.
I suspect some part of the linkage must have been jammed and restored by removing and refitting it all, but this seems too easy. I will keep an eye on it for a while.
