Difflock vacuum solenoid
johanp
Full Name: Johan Pheiffer
Nickname: Johan
Has thanked: 1 time
Been thanked: 26 times
Post by johanp »
Good morning
I believe there are a few forum members who already replaced the solenoids on their Patrols.
Does anybody have an old unit lying around?
I only need a unit with one working solenoid to repair mine.
With some patience I've bent open the metal holder and the solenoids can be removed individually.
I don't want to risk damaging the plug, so I will just cut and resolder the wires.
If there are a couple of these old units around, we can save a lot of money.
It seems that it is always the solenoid that engages the difflock that is faulty.
I am in Pretoria (stay in the north and work in Centurion).
Thank you
Johan
Christovdw
Full Name: Christo van der walt
Nickname: Christo
Re: Difflock vacuum solenoid
Post by Christovdw »
Check with the guys at Nissan Sinoville. (you might be lucky?) They replaced mine last week.
Mrowka
Full Name: Kevin Mason
Nickname: Kevin
Home Town: Kiev
Current 4x4: 1994 Nissan Patrol 4.2TD
Post by Mrowka »
The Aussies usually just install a different solenoid. I don't know the part number but sniff around Patrol4x4 and they may have it.
Патроль - эта вечная машина!
Full Name: Julius
Nickname: Jules
Current 4x4: Pathfinder
GQ Patrol
Home Language: AFR
Has thanked: 94 times
Been thanked: 76 times
Post by Jules »
Change net die pypies om dan werk hy om hom te ontsluit of te sluit , my onderste pypie werk nie so ek lock hom en wanneer ek wil disengage swaai ek die pypies om , ek sal dit doen totdat ek n replacement opgespoor het
Full Name: Gerrit Loubser
Nickname: Gerrit Loubser
Home Town: Richards Bay
Current 4x4: None
Been thanked: 11 times
Post by Gerrit Loubser »
Full Name: Julius
Nickname: Jules
GQ Patrol
Home Language: AFR
Post by Jules »
Gerrit dis tyd dat ons ons Difflocks weer gaan toets op Bainage 4x4
johanp
Nickname: Johan
Has thanked: 1 time
Post by johanp »
Christo
Ek het eers met Dawie by Global gepraat, maar hy moes eers met Wolmer praat.
Dawie het my terug geskakel en gesê as ek daarop aandring kan ek die solenoid kry, maar hy wil dit self op 'n turbo gebruik.
Ek het nie daarop aangedring nie maar Dawie het toe gesê dat ek die solenoid kan kry.
5 minute later het Renier Engelbrecht my gebel en gesê ek kan nie die solenoid kry nie, want hulle het daarvoor betaal en nie jy nie.
Ek het hom toe gevra om weer met Dawie te praat om te hoor hoe hy dit op 'n turbo wil gebruik, maar Renier het gesê hulle hoef nie aan my te verduidelik hoe en wat hulle met die solenoid gaan doen nie. Hulle het dit nodig en gaan dit nie vir my gee nie.
Ek hoop jy het beter diens by hulle gekry.
Johan
Current 4x4: None
Jules wrote:Gerrit dis tyd dat ons ons Difflocks weer gaan toets op Bainage 4x4
Beslis, Jules. :thumbup:
Ek het sopas die Ironmanvere in en die Patrollie is nou vrek hoog. :woo: . Imvubu lyk nie meer soos 'n worshond nie. Miskien kan ek môremiddag laat gou vir jou kom wys, as dit jou pas?
Full Name: Julius
Nickname: Jules
GQ Patrol
Home Language: AFR
Post by Jules »
Yebo klink na n blink plan ek is more so vanaf 15h00 by die huis, dalk sondag mirrag na Bainage toe gaan, ek sal met Peter praat. Jou lorrie lyk seker nou redelik awesome met daardie BF MUDDIES MET N EKSTRA BODY LIFT :woo: :woo:
Current 4x4: None
Jules, ek sal 'n draai maak as ek van die werk af kom, sekernet voor 17h00. Ongelukkig gaan ons kampeer my Mkhuze hierdie naweek en komende week (eers volgende Sondag tuis). Ek sal dus nie kan saamspeel eerskomende Sondag nie. Kan jy dit nie dalk skuif tot die week daarop nie?
