PATROL HEIGHT!
- G-MAN
- Full Name: A.G.HOLMES
- Nickname: G-MAN
- Home Language: Engels
- Has thanked: 3 times
- Been thanked: 9 times
PATROL HEIGHT!
Hi GUYS.
Can anyone please tell me the standard height of a 1999 4500 gl patrol with 16 inch rims and a 2006 4800grx auto with 17 inch rims. Normally measured from the bottom of the rim to lip of plastic trim.
Sucks Gas and Hauls Ass!
- Ross
- Full Name: Ross Holland
- Nickname: Ross
- Home Town: Cape Town
- Has thanked: 7 times
- Been thanked: 14 times
Re: PATROL HEIGHT!
Eish Gerhard...would love to help, but I think thats going to be a tall order.
I recon the majority of '99 4.5 gl`s were probably lifted already by 2001!!
Maybe you still have a shot at the 4.8 though!
For what its worth, I looked back at the OME card from my van (`98 4.2D gl) and the pre-fitment distances with 16inch rims were 755mm for the front and 775 for the rear. I recon those figures should be fairly close to what a std `99 4.5 gl would read.
Post OME (heavy duty kit) the numbers (as of 500km check) were 810mm front, and 840mm rear
Hope that helps a bit?
Cheers,
Ross
Cheers,
Ross
Ross
aka "The Polar Bear"
- G-MAN
- Nickname: G-MAN
Re: PATROL HEIGHT!
Howzit Ross. Thanks for the info buddy
All you beast (4.8s) owners out there
grab a ruler and chuck some numbers my way.
- Saltman
- Full Name: Herbie Hellstrom
- Nickname: Saltman
Re: PATROL HEIGHT!
OK G-man, you got me out of my comfy armchair in front of the TV, into the rain and the garage to take the measurementsThanks for the info buddy All you beast (4.8s) owners out there grab a ruler and chuck some numbers my way.
(I have been wondering about the same thing though ...)
So here it is:
2007 4.8GL (manual) with standard suspension, standard 275/70/16 Bridgestone D694 HT tyres pumped to 2,4 bar and half a tank of fuel.
The front bumper is an ARB unit fitted recently (50 kg) and currently there is one recovery gear ammo box in the rear and a Bosal towbar.
Front reading from bottom of rim to bottom of plastic fender flare: 760 mm (measured through the centre of the hub)
Rear reading from bottom of rim to bottom of fender plastic flare: 765 mm (measured through the centre of the hub)
I suspect the ARB front bumper has made quite a difference. I can certainly feel it in that it feels as if that top bit of flex and articulation has gone compared to the std setup with the plastic bumper. I would suggest you get a front reading from someone with a std bumper.
Saltman:
- G-MAN
- Nickname: G-MAN
Re: PATROL HEIGHT!
Thanks Saltman. Mine measures front 815 and rear 825 but thats with 17 inch rims, so take about 12 off that.
- Gerrit Loubser
- Full Name: Gerrit Loubser
- Nickname: Gerrit Loubser
- Home Town: Richards Bay
- Current 4x4: None
- Been thanked: 11 times
Re: PATROL HEIGHT!
Hi G-Man,
Here are the brow height figures (distance from bottom of rim flange to bottom lip of plastic wheel arch extension) for my 1999 4.5E GRX which is pretty much stock standard other than the 285/75R16 BFG MT KM2 tyres (which don't affect the suspension height) and a Frontrunner Windcheetah 2.2m roof rack (which might have a small effect). My Patrol has almost 220000 km on the clock and has done quite a bit of dirt roads in the hands of the previous owners, so I suspect there would have been some sagging:
Front
Left: 765 mm
Right: 748 mm
Rear
Left: 755 mm
Right: 742 mm
Front
Left: 765 mm
Right: 748 mm
Rear
Left: 755 mm
Right: 742 mm
- G-MAN
- Nickname: G-MAN
- Saltman
- Nickname: Saltman
Re: PATROL HEIGHT!
Jislaaik Gerrit - wat weeg jy?
Hoekom is daar so 'n groot verskil tussen links en regs?
Op my Disco Tdi is die regs voor OME veer ongeveer 10mm langer voor hulle hom insit sodat wanneer die bestuurder alleen ry, dan staan alles level!
Ek dink daai lorrie van jou vra vir nuwe vere ... veral teen daai kilos!
Saltman:
Re: PATROL HEIGHT!
Dis agv van die skuinste van die pad!!
- Vaatjie
- Nickname: Faffa
- Home Town: Welgemoed
- Been thanked: 1 time
Re: PATROL HEIGHT!
Interessant.
Voor: 820mm
Agter: 800mm
Dis hoekom hy so swaar op petrol is. Die ding loop heeltyd opdraend. Sal maar kyk na airshocks/airbags.
Ek het raksisteem met 2 batterye,yskas en ammo krat met recovery gear agter in. Wat snaaks is die voertuig vertoon gelyk.
Voor: 820mm
Agter: 800mm
