Patrol behaving funny
Izak
Full Name: Izak
Nickname: Sakkie
Post by Izak »
Hello
Not funny like in HA HA but funny like in I am WORRIED :think:
Went to Welkom this weekend where we are in the process of renovating a house. All went well and the Patrol worked very hard.
On Sunday morning the Patrol started to idle at 1200RPM. When I engage the clutch and put the car in gear the revs dropped to 600 where she normally idles. This continued the whole day. The EGT was normal, there was no strain on the clutch that I could detect.
We came back to Gauteng last light and the idle stayed at 1200RPM. Stopped in Westonaria where we picked up the children visiting their Grandmother and on leaving her house the Patrol idled at 600RPM. Drove to Alberton, to work this morning and everything is back to normal.
I thought it might be the slave cylinder acting up, low clutch fluid (checked, not that), or a dirty MAF?
The Patrol is due for a service in the next 1000 km.
Thanx
Full Name: Julius
Nickname: Jules
Current 4x4: Pathfinder
GQ Patrol
Home Language: AFR
Has thanked: 94 times
Been thanked: 76 times
Re: Patrol behaving funny
Post by Jules »
Hi Izak
I have had similar problems with my GQ before it went in for a service, but is keeps on popping back on the odd occasion, the mechanic said he put some lubricant or something to the fuel cable apparantly it had some dirt & grime and that made releasing not always smooth sailing
AndriesS
Full Name: Andries
Nickname: None
Home Town: Pretoorsdorp
Has thanked: 28 times
Been thanked: 38 times
Post by AndriesS »
Ek ken nou nie die Diesels so goed nie maar dit klink soos:
1. warm up valve wat sticky is, of sensor wat us is (waar idel die diesels as hulle opwarm)
2. vacuum leak
Saltman
Full Name: Herbie Hellstrom
Nickname: Saltman
Post by Saltman »
Izak, dis tyd vir 'n petrol Patrol ... he he he ...
Ek sal ook voorstel jy kyk na die throttle kabel - maak seker hy beweeg glad en is reg geroute. Moet net nie die binne kabel uithaal nie!!! Jy gaan wragtag sukkel om hom terug te kry en sal waarskynlik eindig deur 'n hele nuwe kabel te moet koop en installeer! Kry iets soos Wynns no 5 of beter (vra die manne wat werk op die goed wat is daar wat goed werk wat jy binne in kan spuit sodat dit in die kabel afloop).
Kyk ook dat niks vashaak by die pomp nie ...
Dit klink na 'n eienaardige ene die - daai 4 silinder diesel rattle so, daar is geen rede hoekom die idle nie na normaal terugkeer nie!
he he he ... jammer man kon nie weerstaan nie, en as jy mooi kyk sal jy sien daar staan so 'n 4 silinder waterpomp diesel engine op my jaart (Tdi 300), so ek weet van ...
Laat wet asb wat die probleem was nadat jy dit opgelos het.
Voorspoed
Herbie
Saltman:
jou kar is DRIVE BY WIRE [daar is nie 'n throttle kabel nie - die pedaal onder jou voet registreer waar jy trap - en stuur elektronies boodskap na die "versneller" van die rekenaar en pas dan die spoed aan soos die 'sensor' se
MAW - daar is vuiligheid by jou pederol peddil [al iss diesel wat hy mee loop]
oftewel - maak skoon waar jy getrap het [kyk vir klippie, stokkie of so iets onder by die pedale - anders is dit die rekenaar wat "LIEG" boodskap kry - NISSAN handelaar se 'console' moet kan wys wat fout is.
Hallo IZAK :oldtimer:
OB1
Full Name: Obus Venter
Nickname: OB1
Current 4x4: Land Rover 110 Tdi Hard top
1997
Post by OB1 »
If it is fly by wire there are plenty of stuff to be checked. As a rule start with the simple stuff first.
Air cleaner check enough air is going trough. Mass Airflow sensor MAF or something measure the air that comes trough, feed to the ECU and that adjust the diesel volume. Faulty reading can cause faulty diese. There are threads on the web where to locate and how to clean it. MAF sensors are expensive handle with care.
Get someone with an OBD2 computer to check for fault readings. Like Kagiso said these get logged and can take you straight to the problem. In most cases it is something simple like earth fault of the sensors. That is what plauged the Discovery2 Td5 so much, might have heard of the 3 amigos in LR circles. In most cases a clean will sort. In some cases you replace that can be expensive since Nissan spares is only available trough the dealers.
Everybody might have heard of a Td5 problem. Interestingly little of it is mechanical, mostly electrical. Also interesting is that a Td5 can run without all sensors but the flywheel position sensor. IE you can disconnect all except this one, the ECU will then default to a pre programmed value for the sensor. The mess is when you dont know which is giving a faulty reading, and you can not disconnect it. The ECU will keep applying the faulty values
tour de frans
Been thanked: 22 times
Post by tour de frans »
Daai kar het n "high idle" of warm up switch.Check dit,of skakel hom aan en kyk of die kar dieselfde spoed idle as wat jy waarneem.
Gu y61 wagon- 6.0L chevy
Gu y61 pickup- 6.2L chevy
