Open door warning light?
- Full Name: Christo van der walt
- Nickname: Christo
Hi Guys,
I purchased my Patrol GRX 2006 4.8 from a dealer about 5 weeks ago. The salesman warned me about the open door warning light that will go on when driving over a rough surface...which I was told is common problem with Patrols? (Apparently the back door?) I've tried to research this phenomenon, but have yet to come across anyone else with the problem. Have any of you guys have experience with this? I really want to get it sorted as it's very irritating!
Re: Open door warning light?
I have the same with 2002 GRX Patrol - but the *&((*&%&*^$(*)&_)(*)_))*& LIEG vir you - lies to you - it is NOT common - it is an adjustment of the latch / catch of the rear door
- Aries66
- Full Name: Louis Naude
- Nickname: Aries66
- Been thanked: 3 times
I have the same on my 2000 4.2TD but it the RH passenger door. Spend half a Saterday to find the culpret, fix it, for a week.
Think of just disconnecting it.
Louis
Louis
Just put a piece of rubber on the spot where the door touch the switch so that there is a bit more movement on the switch's side.
- Nickname: Christo
Thanks for the feedback guys! I'll play around with the rubber and see if I can get it sorted.
- G-MAN
- Full Name: A.G.HOLMES
- Nickname: G-MAN
- Home Language: Engels
- Has thanked: 3 times
- Been thanked: 9 times
All my Patrols did it until I adjusted the rear door!
Sucks Gas and Hauls Ass!
- Pieter du Toit
- Nickname: PJ of ook Whitey
- Home Town: Welgemoed
- Been thanked: 6 times
Funny how some irratating little things can occur with some vehicles - I have never ever had this problem - and my car is the same model as oom Mac's and is the better part of 9 years old!!!
In fact none of the electronics on my car has ever given me any problems!!
It surely amazes me how things from the same brand can have there little irratations.!!
Pieter du Toit
MUFASA
Cell no: 072 606 7007
Fax no: 086 500 9333
MUFASA
- G-MAN
- Nickname: G-MAN
Pieter die Patrol moet klein irritasies he anders sal hy perfek wees.
- Nickname: Christo
Thanks for the feedback guys! One rubber shim/pad sticker on the switch on the back door sorted it.
- Junior Member
- Full Name: Piet Steyn
- Home Town: Somerset west
- Current 4x4: '03 4.8 GRX
Hi Guys
I have a2003 GRX and have the same problem
Put some double sided tape to ensure good contact but did'nt fix it
Took all of the switches out and serviced them, still no fix
Mine has been like this for over a year
Any other possible fixes????
Ek is nou al effens raad-op
