TD42 Starter Motor - 24V
Adrianjvr
Full Name: Adrian
Nickname: Adrian
Current 4x4: '91 SWB Patrol 4.2d
Post by Adrianjvr »
Two weeks ago my starter motor started playing up. The solenoid engages when I turn the key, but the starter motor will not always spin. It has finally got to the stage that she will not start at all. I have checked the batteries and earth connection and all appears to be in order. Any suggestions on what the problem could be?
Has thanked: 1136 times
Been thanked: 1047 times
Re: TD42 Starter Motor - 24V
Hello Adrian
I would firstly suspect the brushes on the starter motor. I had a similar problem a little while ago, ended up refurbishing the starter for R250.00 :thumbup:
Adrianjvr
Full Name: Adrian
Nickname: Adrian
Post by Adrianjvr »
Thanks Peter,
Who did you go to?
Breno fixed my starter's armature.
Hello Adrian
Not sure I really want to recomend this guy, he is a real back-yard mechanic. In the end I had to go and "help" him finish the job. To give him his due though, it was the 24th of December.
Any decent auto-electrician should be able to do the job though.
Peter
Pieter du Toit
Nickname: PJ of ook Whitey
Home Town: Welgemoed
Been thanked: 6 times
Post by Pieter du Toit »
Adrian
Ek wil nou n nie stupid klink nie maar hoekom verwys jy na n 24v starter?? Is jou engin 24v??
Pieter du Toit
MUFASA
Cell no: 072 606 7007
Fax no: 086 500 9333
Adrianjvr
Full Name: Adrian
Nickname: Adrian
Post by Adrianjvr »
Ja, dis mos a trok. Hopefully I can get it repaired cheaply, I would hate to know the cost of an imported starter.
Adrianjvr
Full Name: Adrian
Nickname: Adrian
Post by Adrianjvr »
The starter motor is working again after hitting it couple of times with a hammer out of frustration. :woo: There really is not space under the hood to get the the starter motor bolts!
Dis dan heel moontlik die borsels wat klaar is - het die selfde probleem by Vic Falls gehad. Jy kan die borsels los koop by Breno.
tour de frans
Been thanked: 22 times
Post by tour de frans »
Pieter,verkoop jou24v starter aan Adrian.
Gu y61 wagon- 6.0L chevy
Gu y61 pickup- 6.2L chevy
