Anyone here turbo'ed a TD42?
weskus_surfer
Post by weskus_surfer »
Hi All,
I've posted this here because it's not really about the technicalities of the turbo installation and thus I dont want to spam the techie categories.
So.. anyone added a turbo to a TD42? Were you happy with the outcome performance vs. fuel economy?
My biggest concern is that not many people have done this mod in SA so your SACs of the world might mot be familiar with the best set-up.
Koos; I know you were contemplating this route. What's your 2c?
GQ Patrol, 4.2D
KOOS BEST
Nickname: Kosie
Home Language: TWEETALIG
Re: Anyone here turbo'ed a TD42?
Post by KOOS BEST »
Len, yes I wanted to but bought a GU for a bargain, but my investigation showed me the guy to speak to is at Megawarld CPT Dennis Maytom, his the guru , he would have bought me the kit in Oz and bring it over. He speaks with authority about this conversion, all the other guys seems to be a bit amateurs in this.
Apparently its a a different vehicle after the conversion(much better).
That my 2c
Land Rover Discovery 3 TDV6
weskus_surfer
Thanks Koos. Seems like all Patrol roads lead back to Dennis
GQ Patrol, 4.2D
tour de frans
Been thanked: 22 times
Post by tour de frans »
Hi weskus surfer
Ek het my 4.2 geturbo.alles homemade die exhaust manifold ens. Ek het dit baie goedkoper gedoen as wat n kit kos.Ek het met Dennis gepraat en hy het my gehelp met n injectorpomp.My Patrol loop baie goed,ek beplan om my kar op die dyno te sit om te sien of alles reg loop en wat die krag is.Diesel verbruik dink ek is goed.Die kar gee my 6.6kml teen 130/140 kmh.Die Patrol loop 140kmh gemaklik vol gelaai.
Ek moet se dis n ander kar met die turbo,ek kan nou met gemak verby steek,bulte klim ens. :layrubber: (ek sien kans vir die ingevoerde kits :biggrin:)
Groete Frans
Gu y61 wagon- 6.0L chevy
Gu y61 pickup- 6.2L chevy
Ratau
Full Name: Danie Terblanche
Nickname: Danie
Current 4x4: 2000 Nissan Patrol 4.2 diesel / DIY Turbo Conversion.
485 Nm@1300Rpm NA
Post by Ratau »
Frans
Het jy dalk 'n foto of twee? Spesifiek van die manifold. Waaruit het jy die manifold gebou en is dit een of twee stukke? Het jy ook ʼn intercooler op? Het jy turbo spesifikasies?
Ek dink dit help baie vir die asemhaling al is die boost net 5 tot 7 pond sonder om die pomp oop te draai.
Danie
Live while you’re alive!
KOOS BEST
Nickname: Kosie
Post by KOOS BEST »
Het julle ouens die een gesien wat ek raakgeloop het in "FOR SALE SECTION". As ek nou die geld gehad het , het ek dit gekoop. Verkoop julle voertuie en koop daai een .Stuur vir my n e pos dan stuur ek julle die fotos aan.Die Troll het ALLES wat jou hart begeer , absoluut alles!!!!!!!!!!!!!!!!!
Ratau
Nickname: Danie
485 Nm@1300Rpm NA
Post by Ratau »
Koos
Stuur asseblief die foto's na danie at ntp.co.za
Danie
KOOS BEST
Nickname: Kosie
Post by KOOS BEST »
Ratau, dit is in die pos .
Koos
Ross
Full Name: Ross Holland
Nickname: Ross
Home Town: Cape Town
aka "The Polar Bear"
Has thanked: 7 times
Been thanked: 14 times
Post by Ross »
Hi Weskus Surfer,
Yep, my GU is turbo`d. The conversion was done by Alpine Developments (by the previous owner) and I am very happy with it. The Alpine set up is fairly conservative. It uses a mitsubishi TD04 turbo, and a smallish front mounted intercooler, and runs fairly low boost (0.4bar).
I have driven the std 4.2D on a number of occasions, and the turbo definately transforms the vehicle. My particular setup gives 113kw and 402nm, which is quite a decent increase compared to the std figures. In a recent trip to Zambia and Botswana where I travelled in convoy with a Non Turbo 4.2D, the fuel consumption figures were more or less identical. We both had RTT`s, and roof racks and were running 33" M/T tyres, and on the open road both vans were getting about 14.4l/100km.
The vehicle is more relaxing to drive on a long trip once you have the turbo as you never have your foot hard down just to maintain cruising speed. Performance wise I would say that the turbo brings things pretty close to a 4.5 petrol Patrol (you still have less kw, but this is balaced by greater torque).
These motors are very strong, BUT you will kill it if the conversion is not done properly. In this regard an EGT gauge is a must, and I would not personally run more than 0.5bar boost if you want to retain the longevity of the motor. As a precaution I have reduced my oil change intervals from 10 000km to 5 000km, since the oil works a lot harder with a turbo fitted. In my understanding, the early GQ spec 4.2`s (pre '94 I think?) had a stronger build (beafier pistons and conrods), and these can be turbo`d more agressively, the later motors are still very strong but must be treated with some respect in the turbo`ing process.
As long as you do your homework and make sure of a competant installation, this is a conversion that you will definately not regret!
My 2c
Ross
weskus_surfer
Thanks for all the feedback guys.
GQ Patrol, 4.2D
