LSD Oil - urgent
- Russ Kellermann
- Has thanked: 8 times
LSD Oil - urgent
Hizit lads,
Where can i get Limited slip diff oil from , and possibly a friction modifier too. Agents quoted me R203 per Lt @ 5.0 Lt = R1000 odd bucks - after vomiting in my mouth a little i decided to ask you boys for alternatives..... I'd love to have this info within 24 hours.
thanks
Ps: I heard of Castrol LSX doing wonders for the Lsd but where can i get this ? Other brands also welcomed though.
thanks
- David
- Full Name: David Prinsloo
- Nickname: David
- Home Town: Stellenbosch
- Been thanked: 49 times
Re: LSD Oil - urgent
Russ, In Brackenfell I would go to 'Goeie Hoop Onderdele' - they have everything!
http://www.goodhopespares.co.za/
Not so sure where to go in the southern suburbs though....
I have used Castrol LSX with great success in my old Safari
- Desert eater
- Newbie
- Full Name: Henk Buitendag
- Nickname: Henk
- Current 4x4: 2006 BMW X5 3.0D
2000 Nissan Patrol TD 42 - Home Language: Afrikaans
Ek gebruik Castrol
- Ross
- Full Name: Ross Holland
- Nickname: Ross
- Home Town: Cape Town
- Has thanked: 7 times
- Been thanked: 14 times
Hi Russ
Suburban Spares in Ottery used to have it, I have also seen it at Tonnesons in Claremont. I think its fairly commonly stocked by most of the spares shops so I`m sure if you make a few phone calls you`ll come right.
SRXy`s LSD runs with Castrol LSX.....it had been running with normal diff oil for quite a while and was basically dead (ie open diff!!), but after washing everything out with paraffin a few times, and re-filling with LSX, the LSX has really brought it back to life!
Ross
aka "The Polar Bear"
- Russ Kellermann
Thanks guys.
Ross, This is exactly what has happened to mine. Nissan put normal oil in my rear diff and it is obviously not operating the way it should. I am so furious with them. However, Nissan are useless and crying over spilt milk is a waste here, unless the diff was damaged, then i would go mental! I plan on purchasing the LSX and running the vehicle for about 100 km, then drain again and fill again, however, with the agents quoting me over R1000 i cannot do this, i need a solution in the form of the cheaper LSX.
I will call around first thing tomorrow for this..... hold thumbs guys!
Castrol LSX is the best for the LSD
- G-MAN
- Full Name: A.G.HOLMES
- Nickname: G-MAN
- Home Language: Engels
- Has thanked: 3 times
- Been thanked: 9 times
Russ, pop into midas down the road of you. Riaan will be the man to speak to!
Sucks Gas and Hauls Ass!
- Russ Kellermann
Will do, gonna ring him first thing.
Why is it then that Nissan LSD oil, and , SOS Cape town oil suggestion of (Gear oil GL5 75w 140 Full Synth) , is literally 5 times the price, surely there's a reason?
- G-MAN
- Nickname: G-MAN
- davejones
- Full Name: David Jones
- Nickname: David
- Home Town: Lagos, Nigeria
- Been thanked: 6 times
An ox, but with balls !!!
