How to recover a grader
- Full Name: Ruben Roach
- Nickname: Ruben
- Home Town: On a farm in Middelburg
Nissan Hardbody 2.4 - Home Language: Afrikaans
Ok, so it all started about two weeks ago when a quick drive around the farm ended up in an exciting recovery. We first attempted to recover the stucked Patrol with the 4x4 Landini tractor, but the tractor also got trapped. The day ended with me admiring the great benefit of a winch as this was the only means of recovering the Patrol. The Landini was recovered by two other tractors in tandem.
This exciting event initiated a call to get a grader to repair the farm roads on the eastern side of the farm as the exit roads on the western side were becoming too wet and muddy for daily travel. So this Saturday the grader arrived to come and cut our farm roads. The problem was that the driver decided to work on the farm roads on the western side of the farm, and this is where the trouble started. I was in town when I received a call that the grader was stuck. When I arrived at the spot I attempted to recover the grader with my winch. I admit that this was a farfetched idea, but I had to try. The next option was the Landini, but the tractor could not even move the grader. It was here that we realised it was time for the big guns. We had to get the excavator of the nearby mine. The heavy excavator had difficulties reaching the grader and had to at times recovery itself. The grader also had to dig a road towards the grader. The excavator started south from the grader and crawled/digged north towards the grader for about 60 to 80m. This resulted in the transformation of a small “twee spoor” farm road into a muddy road pit looking like a dam.
The photos below describe the event the best.
- Nickname: Ruben
Re: How to recover a grader
Here is two more pics of what the road looks like now. It will be years before we can use it again.
Ruben
1999 Nissan Patrol 4.5 GRX
- Russ Kellermann
- Has thanked: 8 times
Cool story! and pics!
Cold you not land fill that "dam" now and once it settles and packs, then grade it flat with a light duty grader or dozer with a grading front end? just throwing around ideas, i have no idea what could....
fill up with old used tyres [should be packed but time & labour will dictate if you pack 'm or toss'm ]
fill with sand as you go - and the last section - if you can find some rocks, throw these in. Then cover with sand on top.
Never get stuck again and prevents erosion forever.
But that is BIG work. Just a thought - nt even
- Has thanked: 1136 times
- Been thanked: 1047 times
Hi Ruben
My experience says you must stabilize and fill that hole ASAP otherwise that patch will be a problem every time it rains.
Old tires are good, but building rubble or whatever will work just as well. We also used to use old anthills. They set rock hard.
Peter
Peter
Hi ruben
krisis meneer julle maak groot gate as julle dit doen !!!!!
ek weet niks van padbou nie so ek kan nie help nie maar gelukkig het jou patrol low range en n winch!!!!!
dit lyk of jy dit gaan nodig he
- Mammoth
- Full Name: Johan Botha
- Nickname: JB
- Home Town: Roodepoort
- Current 4x4: Nissan Patrol 4.5GRX
- Been thanked: 5 times
Ek wonner maar net....
Hoekom di gat toemaak as jy nou so lekker speelplek het.... Ek sit wraggies eerder in daai gat vas om in die kantoor agter n' tafel te sit met n' das wat jou wurg.......
JB
(Mammoth)
(Mammoth)
- Nickname: Ruben
Dankie vir die raad manne.
Ek gaan wragtig honderde ou bande nodig he om daai gat toe te maak. EK besluit nog wat om te maak.
Mammoth jou plan werk ook vir my. Miskien moet ek dan eerder die gat in n orderntlik 4x4 baan omskep
Ruben
het jy nou jou gat gesien? sal jou leer om met uclids te ry waar Patrol huiwer ...
Ek dink meeste van di ebande plekke sal maar te dankbaar wees om 'n gat te he waar hulle bande kan dompel [Ex swaer Koos inni Vrystaat het erosie slote so herwin - [het hom weliswaar 'n klompie jare geneem]
Maar AS jy hom nou wel 'n 4x4 speelplekkie wil maak - Wat gaan jy die "trail" noem?
ja!!!!maak dit n speelplek ons gaan vir jou kom kuier
hou net daai excavator naby want as my patrol gaan le in die modder het jy n erinstige masjien nodig om hom daar uit te kry!!!
