Bash Plates
Has thanked: 1141 times
Been thanked: 1049 times
Bash Plates
Hello Ladies and Gentlemen
To try and limit confusion, I have decided to start a new thread on this. Also, my apologies for the long delay.
I have now had the opportunity to measure a wide variety of Patrols, and I am reasonably confident that I can now manufacture a bash plate for any Y60 or Y61 patrol. Basically, there are three variants. These are the Y60, the Y61 with all engines except the 4.8, and then the 4.8. Some aftermarket bumpers on the Y60 use the mounting points I would like to use, but on these the Y61 bash plate should fit. There is also a special version for the Y61 (non 4.8) with ARB bull bar which is longer and joins to the bull bar, specifically designed for Izak.
The bash plates are all manufactured from 5mm Mild steel. Prices for all the bash plates except the special Y61/ARB will be R850.00 in raw steel or R950.00 if you want it galvanized. The Y61/ARB will be R1100 raw or R1200 galvanized. Delivery should be around three weeks from the day I place the orders.
50% minimum deposited to FNB Woodbridge branch, account number 62246897659 (savings account) with proof of payment e-mailed to peterconnan@za.spiraxsarco.com secures your order.
Peter
Re: Bash Plates
Sorry guys, I forgot to add:
Please also remind me what you drive (model, engine and bumper). This does not apply to the guys whose cars I measured.
Also, these bash plates are all designed to be able to accomodate two bow shackles for recovery purposes, and grass seed netting attachment points.
Peter
Wynvat
Full Name: Gerhard van Rhyn
Nickname: Wynvat
Re: Bash Plates
Post by Wynvat »
Thanks Peter
Ordered, paid (50%) and e-mailed.
(Bashplate and Transfer Case Skidplate).
Gerhard
Re: Bash Plates
hey piet moet ek eers n bumper opsit voor die bash plate sal pas ????
Re: Bash Plates
Tinus the standard bash plate for your 4.8 will fit with every bumper I have yet seen.
For the guys with the other engines, basically the same goes. The bash plate will fit with every bumper I have seen, with the possible exception of ONCA, which has it's own bash plate.
Peter
Re: Bash Plates
P/ter - se vi oompie, daai "underbelly" plate wat Agarob nou reeds het en die "bash-plate" wat nou oppad is - helle sal so saam-saam kan werk mos? ek meen, hulle gaan nie baklei oor vasmaak 'spots' nie??
BRILJANT van jou om die 'saadnet' ankers by te sit ... dit alleen is oorie honneert punte werd !!
Ek stoei nog steeds met Hennie vir pryse op die uitswaaidakkie se seile.. ek kry al skaam vir sy part.
Ek gaan Noorde se kant toe - ek sal dan ook by Tannie Miem stop en hoor wat sy kan uitrig.
Re: Bash Plates
Dis reg Oom Mac, die twee plate baklei nie met mekaar nie.
Was oom saterdag by Hennops? Ons was daar, maar ek kon Oom nie raakloop nie. Het wel Christo, Cedrick en Kobus te siene gekry, maar daar was seker amper honnert karre daar. Baie suksesvolle dag vir die Nissan club ne?
Partykeer is dit amper onmoontlik om ouens te kry om te kwoteer. Ek hoop maar dit beteken dit gaan so goed met sy besigheid dat hy nie ekstra werk nodig het nie?
Peter
Stefan
Full Name: Stefan de Villiers
Nickname: Stefan
Re: Bash Plates
Post by Stefan »
order sent!
Wilfred Moore
Full Name: Wilfred Moore
Nickname: Wilfred
Been thanked: 4 times
Re: Bash Plates
Post by Wilfred Moore »
Peter, deposito paid and sent.
Thanks for your trouble !!
Wilfred
DaveH
Junior Member
Junior Member
Full Name: Dave Henson
Nickname: Dave
Home Town: Midrand
Current 4x4: 2007 Nissan Patrol 4.8grx
Re: Bash Plates
Post by DaveH »
Peter
Thanks for the trouble. I have ordered 1 galvanised bash plate and 1 transfer case cover for a 2007 4.8grx Patrol and sent 50% deposit to you.
