Right rear barn door
- davejones
- Full Name: David Jones
- Nickname: David
- Home Town: Lagos, Nigeria
- Been thanked: 6 times
Has anyone notice negative effects from having larger than standard tyres on the right hand side rear barn door?
Mine's not quite looking as flush as I remember (I'm also always inventing things to go wrong according to swambo), also clacking a bit so will check out Gerrit's fix according to http://www.patrol4x4.co.za/viewtopic.php?f=46&t=848 ..
My wheel bracket is extended through a bunch of washers. I occasionally use the spare wheel to get onto the roof rack, as a table to get things onto the roofrack etc, pretty sure repetitive use this way isnt great in the long run, but again the door looks pretty well secured.
David
David
An ox, but with balls !!!
- Has thanked: 1136 times
- Been thanked: 1047 times
Re: Right rear barn door
Hi Dave
No problems yet with mine, although it has squeecked and leaked dust ever since I got it. I also use mine as ladder etc.
Peter
Peter
- Izak
- Full Name: Izak
- Nickname: Sakkie
- Home Town: Alberton
- Been thanked: 3 times
My tyres are not that much bigger than standard but, I AM, and I have used the tyre as a ladder for a year now. Even with the frontrunner ladder I still sometimes use the spare as it is less hurtfull on the feet...
In short, no negative at all
- Pieter du Toit
- Nickname: PJ of ook Whitey
- Home Town: Welgemoed
Hi Dave
Have quite a bigger size tye than normal (305/70/16 compared to 265/75/16 standard) on my door - had to havemy bracket modified quite a bit. A part from the door being quite a bit heavier I have not noticed any negative effects - yet!! Had the bigger size tyre on there for just over a year now.
I do have a ladder on the right hand door but like everyone else also us he spare as a step between getting onto and off the roofrack. I do get a bit of dust in and have noticed a rattle on my rear doors when driving badly corrigated roads - normal tar or gravel / dirt roads and its fine.
Pieter du Toit
MUFASA
Cell no: 072 606 7007
Fax no: 086 500 9333
MUFASA
- tour de frans
- Been thanked: 22 times
Psssst Pieter,daai trap is op jou linker deur.
Gu y61 wagon- 6.0L chevy
Gu y61 pickup- 6.2L chevy
- Junior Member
- Full Name: Kobus du Toit
- Nickname: Kobus
- Home Town: Oudtshoorn
- Current 4x4: 1999 Patrol 4.2D GL
2002 Hilux D/C 3.0 KZ-TE - Home Language: Afrikaans
- Been thanked: 1 time
I don't think it really matters how big the wheel/rim combination is - to a certain degree we are all experiencing exactly the same symptoms. My Patrol (one of those EU-versions which one very often sees in Zim, Zambia, Malawi, Moz, etc.) was factory fitted with 6jjx16 rims and 235 tyres, a combination I would think shouldn't put too much stress on the rr barn door. Not so - it squeaks when you open it, rattles on corrugated roads and is everything but dust proof! And who doesn't use the spare wheel as a ladder?
So in this case it is different but same same.
Kobus du Toit
1999 Patrol 4.2D
2002 Hilux D/C KZ-TE 4X4
1971 Peugeot 404 S/W
1999 Patrol 4.2D
- Pieter du Toit
tour de frans wrote:Psssst Pieter,daai trap is op jou linker deur.
Dankie Frans - die blondgeid slaan sommer weer hoog deur so vroeg in die nuwe jaar -
Pieter du Toit
MUFASA
MUFASA
- David
- Full Name: David Prinsloo
- Nickname: David
- Home Town: Stellenbosch
- Been thanked: 49 times
Nie as jy hom van voor af kyk nie!tour de frans wrote:Psssst Pieter,daai trap is op jou linker deur.
- tour de frans
- Grant
- Full Name: Francis
- Nickname: Grant
- Home Town: Rosendal
- Has thanked: 3 times
- Been thanked: 26 times
Hi Dave,
I have a 285/75/16 Big Horns on and no Problem. I have fitted the 1,6 m high lift jack to the rear and now I believe I have a problem. Problem is I do not know where else to put it.
