NEW GU REFERENCE DOCUMENT
KOOS BEST
Nickname: Kosie
Home Language: TWEETALIG
Post by KOOS BEST »
Hi to all, especially GU 3.0D owners. Look on Aussie web site they just updated the latest ref. doc. for the Patrol. Load it off , its on PDF format. I regard it as the Patrol Bible. Very very informative and excellent info.
Koos
Hello all, Version 2.0 is now up. Enjoy.
Download links are back up and running again.
Download black and white version (11 MB) here: ZD30 Y61 Reference Document BW.
http://www.video2000.com.au/zd30/ZD30%2 ... -%20BW.pdf
(JohnBoy ge-Fix) :idea:
Download colour version (15 MB) here: ZD30 Y61 Reference Document Colour.
http://www.video2000.com.au/zd30/ZD30%2 ... Colour.pdf
Thank you Koos! I'm adding the TOC below and making this pots a sticky.
CONTENTS
INTRODUCTION..................................................................................... 5
ZD 30 SPECIFIC (Mostly) .......................................................................... 6
Engine Protection............................................................................................ 6
Spares ...................................................................................................... 8
After/During an Engine Rebuild........................................................................ 9
Reliability ....................................................................................................10
Test If Your Vehicle Is Affected By Over Boost – How To ............................................12
How I Tested My Own Vehicle.........................................................................12
In Summary...............................................................................................13
ELECTRICALS ......................................................................................15
Air Bag(s) System - Disabling..............................................................................15
ECU Fault Codes - GU ......................................................................................16
Manual Extraction.......................................................................................16
Fault Code Table ........................................................................................16
Clearing Fault Codes....................................................................................18
Key in ignition alarm.......................................................................................19
Spot Light Wiring Diagram.................................................................................20
Stereo Wiring Diagrams ....................................................................................21
MAINTENANCE.....................................................................................22
Maintaining Your Tyres.....................................................................................22
Tyre Inflation ............................................................................................22
Checking Tyre Tread....................................................................................22
Wear On Both Edges: UNDER INFLATION ............................................................22
Wear In Centre: OVER INFLATION ....................................................................22
Cups or Dips in the tread: WORN PARTS.............................................................22
Sawtooth edges: MISALIGNMENT......................................................................22
Tyre Balancing...........................................................................................23
Vehicle Alignment .......................................................................................23
Tyre Rotation ............................................................................................23
Repairing Tyres ..........................................................................................23
MECHANICAL.......................................................................................24
5th Gear Failure GU ........................................................................................24
Belt Tensioners ZD30.......................................................................................25
Exhaust Gas Reticulation System (EGR).................................................................26
EGR Blocking – How To.....................................................................................28
Principle ..................................................................................................28
Tools.......................................................................................................28
Disassembling ............................................................................................29
To reassemble ...........................................................................................29
EGR Technical Diagram....................................................................................30
Earthing Issues...............................................................................................31
Flat Mirror on GU4 (non convex) .........................................................................32
Free Wheeling Hub Diagrams- Manual...................................................................33
Keyless Remote - Reprogramming .......................................................................34
Oil Catch Can – How To Make Your Own and Install...................................................35
How to do it..............................................................................................35
Bits required and costs.................................................................................41
Installation ...............................................................................................41
Oil Pressure Gauge Sendor Install ........................................................................44
Introduction..............................................................................................44
What you will need .....................................................................................45
Nissan Patrol Reference Document
Page 3 of 120
How to do it..............................................................................................45
Rear Brake Force Less Due To Lift Kit – Brake Proportioning Valve ................................48
What Is It – A Technical Explanation.................................................................48
What Is It – A Plain English Explanation .............................................................48
Putting The Above Technical Jargon Simply........................................................49
How To Do And Examples ..............................................................................49
Cracked Rear Chassis.......................................................................................52
Speedo Correction..........................................................................................53
Introduction..............................................................................................53
How Do You Fix Your Speedo Being Out?............................................................53
Steering Castor Correction – After Lift ..................................................................57
Which Kit .................................................................................................57
Technical Explanation..................................................................................57
Other Tyre Wear– Simple Explanations ..............................................................58
Sway Bar Extension Bracket Kit – After Lift ............................................................59
VNT Screw Adjustment.....................................................................................61
TRIMS, MOULDINGS ETC..........................................................................63
Bubbling Dash................................................................................................63
Drivers Seat Movement - GU ..............................................................................64
Pollen Filter Kit .............................................................................................65
Trims - Silver Plastic on Doors and Dash................................................................66
WHITE PAPERS, BULLETINS AND PRODUCT TESTING........................................67
Air Filter Test Report - Spicers ISO 5011 Duramax ....................................................67
Scope......................................................................................................67
ISO 5011 Test ............................................................................................67
Capacity and Efficiency ................................................................................67
Flow Restriction.........................................................................................67
Filter Efficiency .........................................................................................68
Accumulative Capacity.................................................................................68
Accumulative Gain......................................................................................69
Initial Restriction........................................................................................69
Dirt Passed Versus Total Test Time ..................................................................70
Dust Loading .............................................................................................70
Restriction to Flow......................................................................................71
Test Data Tables ........................................................................................71
The Story Behind The Test.............................................................................75
Chip Tuning or Performance Modules or Electronic Tuning Devices................................77
What Are They...........................................................................................77
Diesel Tuning Devices ..................................................................................77
Chips And Computers - How Do They Go About Improving Performance? .....................78
Basic Basic Basic Universal Fuel Increase Units....and Cheap To Manufacture ...............78
Basic Basic....Multi Point Fuel Adjustment .........................................................79
Desirable Fuel Mapping.................................................................................79
Independent Injection Timing.........................................................................80
Engine Durability ........................................................................................81
Programming, Numbers, Data - The Stuff That Goes Into a Computer.........................82
Conclusions...............................................................................................83
Differentials (Diffs).........................................................................................84
What Are They...........................................................................................84
A Standard (Open) Differential .......................................................................84
Traction-Adding Devices ...............................................................................84
Whats A Locking Differential Or Locker .............................................................85
Intercoolers..................................................................................................87
What Are They...........................................................................................87
Air To Air Intercoolers..................................................................................87
Page 4 of 120
Front Mounting An Intercooler? .......................................................................88
Air-To-Liquid Intercoolers .............................................................................88
Mass Airflow Sensor (MAF).................................................................................89
What Is It .................................................................................................89
Hot Wire Sensor .........................................................................................89
How To Remove .........................................................................................90
Nissan Bulletin On ZD30 Engine Oil – Sept 2004........................................................91
PCV Valve ....................................................................................................92
Explanation...............................................................................................92
History ....................................................................................................92
PCV System...............................................................................................93
Operation.................................................................................................93
Trailer Wiring Diagrams....................................................................................95
Turbo Tech 101 ( Basic ) By Garrett .....................................................................96
Tyre Terminology ......................................................................................... 102
All Terrain Tires ....................................................................................... 102
Mud Terrain Tyres..................................................................................... 102
Bias-Ply Tyres and Radial Tyres..................................................................... 102
Radial ................................................................................................... 103
Reading a Tire ......................................................................................... 104
Light Truck Sidewall Designations.................................................................. 106
Tire Components ...................................................................................... 106
Winch Considerations .................................................................................... 109
Major Considerations ................................................................................. 109
Other Considerations ................................................................................. 110
Winch Components.................................................................................... 110
Winch Solenoid ........................................................................................ 112
Wheel Terminology ....................................................................................... 113
A few terms ............................................................................................ 113
Why Synthetic Oils Are Superior........................................................................ 115
Engine Oil Basics ...................................................................................... 115
What Is Lubricating Oil? .............................................................................. 115
There Are Four Different Types of Motor Oil Base Stocks ...................................... 115
And There Are a Variety of Additives .............................................................. 115
Let's Look at Conventional (Mineral) Oil........................................................... 116
Hydroprocessed Oil ................................................................................... 116
Severe Hydroprocessed Oil .......................................................................... 116
Semi-Synthetics........................................................................................ 116
Synthetics .............................................................................................. 116
Base Oils Summary.................................................................................... 117
So What Does This All Mean? ........................................................................ 117
There Is a Clear Difference in Motor Oil Protection and Performance....................... 118
GLOSSARY ........................................................................................ 119
Land Rover Discovery 3 TDV6
Re: NEW GU REFERENCE DOCUMENT
Koos het jy vir ons die link?
KOOS BEST
Nickname: Kosie
Post by KOOS BEST »
http://www.patrol4x4.com/forum/showthread.php?t=31418
I dont know how to post it , maybe this will help
Koos
JG Shields
Full Name: JG Shields
Nickname: JG
Post by JG Shields »
Thanks Koos. This is of great help!
Patrol fan!
Tjaart
Nickname: TJ
Current 4x4: Patrol 4500 GRX
2000
Post by Tjaart »
Koos
Het jy dalk so 'n dokument vir die TB45E engine? Y61? :helpsign:
THE BRAVE
says
Aut PATROL aut nihil
Aut vincere aut mori
KOOS BEST
Nickname: Kosie
Post by KOOS BEST »
Nee, jammer Tjaart. Maar die dokument het betrekking tot jou voertuig ook, hulle bespreek net nie baie van jou enjin nie, maar daar is baie ander info wat jou kan help.
Groete Koos
Wynvat
Full Name: Gerhard van Rhyn
Nickname: Wynvat
Post by Wynvat »
Dankie Koos, het dit afgelaai en gedruk. Dis baie handig. Hoop hulle gradeer dit op na die petrolenjins toe ook.
Wynvat
Nickname: Wynvat
Post by Wynvat »
I wish I could get hold of one of these!
Tjaart
Nickname: TJ
2000
Post by Tjaart »
kyk bietjie op ebay. Daar is van hulle daar
Ek het een op CD!! :thumbup:
THE BRAVE
says
Wynvat
Nickname: Wynvat
Post by Wynvat »
Hallo Tjaart
Die een wat ek op ebay kon sien is nie meer beskikbaar nie.
Ek het vir jou 'n PM gestuur.
Groete,
Gerhard
