Glow Plugs on a 4.2D
- Russ Kellermann
- Has thanked: 8 times
I need new glow plugs boys, i'm thinking NGK. Where can i buy these for the 4.2D - If they anything like the belts for this motor then i'm not gonna find them aftermarket. But surely?
- Ross
- Full Name: Ross Holland
- Nickname: Ross
- Home Town: Cape Town
- Has thanked: 7 times
- Been thanked: 14 times
Re: Glow Plugs on a 4.2D
Available from Toneson in Claremont, should be able to post a part number for you later......watch this space!!!
Ross
aka "The Polar Bear"
- Ross
- Nickname: Ross
Russ you are looking for the following part number for the glow plugs:
NGK 4937Y-707RS
They are sold individually, so you need that X6
Let us know if you come right, as I need to buy a set soon as well!
NGK 4937Y-707RS
Ross
- Russ Kellermann
Ross, thanks for going through the effort and replying with such detail, i really appreciate it.
- Ross
- Nickname: Ross
No worries!
Hooray for the forum!
Ross
- ChristoSlang
- Nickname: ChristoSlang
- Home Town: Pretoria, ZA
- Has thanked: 29 times
- Been thanked: 136 times
I've used:
- VSP brand, part number ELP.PN135
- HKT brand, part number PN-135
- SRXy
- Full Name: Wes
- Nickname: the Knob...
- Home Town: Slaapstad
- Current 4x4: TD42T Patrol "The Wee Beasty", 373,000km's
Umm....this is a Patrol forum isn't it? - Home Language: engles
- Been thanked: 1 time
The part numbers that Ross gave are the ones I put in. They really did the job....and have about 20,000km's on so far. These are specified for the TD42. They come out in both 12V and 24V versions...so make sure you get the right one for your trucks specifications.
I paid R600 for 6 of them (end of 2008)
- Russ Kellermann
Big problem - I got them, but i didn't know about the 12v or 24v story, i thought only the cruisers had 12 and 24v differences. Now what? They working, so thats good, but i don;t want to damage anything? If they were the wrong voltage, would they be working?
- ChristoSlang
i think you ended up with the correct ones...
If they were meant for a 24V system they're likely to have a bigger resistance than the 12V ones (to limit current flow, thereby retaining the same wattage rating). As a result of that, they'd generate only about half the heat (i.e. "glow") when used with a 12V system, same effect as putting 24V bulbs into a 12V headlamp. Remember that wattage translates directly into heat!
So: 24V glow plugs won't damage the electrical system, will consume less current whilst working but will probably be useless in winter
