Fitting it I find it strange theres no screw or clips, it slides in beneath the headlight and gets hold in place by the bonnet closing, it does sits tight once closed. Do any of you have protectors fitted the same way.Seems to be a bit loose .
Koos
Note it just clips over the top of headlight only and slides in beneath the white strip and rubber seal on bull bar
