Y61 (GU) Handbrake
- Nickname: Kosie
- Home Language: TWEETALIG
Y61 (GU) Handbrake
Mod's Note: This thread has been split off this thread.
Re. the Handbrake, why I am asking picked up a Patrol brochure the other day from Nissan and saw on the brochure it stated Diesel with Transmission Handbrake and Petrol on the back wheels, WHY? THE DIFFERENCE.
Maybe its new but it stated 4.8 have different handbrake.
Koos
Koos
Land Rover Discovery 3 TDV6
Re: 4.8 FUEL CONSUMPTION
Koos het nog daai pamflet? Miskien moet ek dit met Nissan opneem!
- Nickname: Kosie
Y61 (GU) Handbrake
Herrie, ja ek het hom, dit is die huidige een beskikbaar uit showrooms van Nissan
Koos
Koos
- JohnBoyZA
- Site Admin
- Full Name: John Murray
- Nickname: John Boy
- Home Town: Bloubergstrand
- Current 4x4: Patrol GRX 4.8
- Has thanked: 1046 times
- Been thanked: 231 times
Ek het die brosjure.
3.0 TD GL 4x4 P65: Mechanically operated on propeller shaft
4.8 GL 4x4 P63: Mechanical, on rear axle
4.8 TIPTRO GRX 4x4 P64: Mechanical, on rear axle
- Gerrit Loubser
- Full Name: Gerrit Loubser
- Nickname: Gerrit Loubser
- Home Town: Richards Bay
- Current 4x4: None
- Been thanked: 11 times
Originally the Y61s all had transmission mounted parking brakes; even the very early 4.8s, I think. Somewhere in the middle of 2002 the 4.8 got larger diameter brake discs, presumably making it possible to fit drum-in-disc park brakes to the rear wheels, which might work out cheaper than the single larger drum brake on the transmission. The other models did not get bigger brakes, but retained the awesome transmission mounted park brake.KOOS BEST wrote:Another thing why does the Petrol Patrols have normal handbrakes and the diesel the transmission handbrake.
Koos
I must say, I love my 4.5's park brake. Compared to the mediocre performance one normally gets from a drum-in-disc setup, it is amazing. How do owners of the 4.8 find its drum-in-disc park brake?
- Saltman
- Full Name: Herbie Hellstrom
- Nickname: Saltman
Re: Y61 (GU) Handbrake
I have not yet handbrake-parked the Patrol with my trailer attached against a steep mountain slope, but in all other conditions I have not yet had any problems.
I prefer the rear wheel handbrake as a result of the problems experienced with the Land Rover transmission brake setup. The Landies are renowned for leaking oil which would find its way into the brake shoes of the transmission mounted drumbrake ... and the sand would stick to the oil and start a sandpapering exercise and from there on it is just downhill, pardon the pun! I also dislike the up to half a metre of roll that the transmission mounted jobs have. No such issues with the rear wheel handbrakes. Hulle vat vas!
Are there issues I need to watch out for with the rear wheel drum in disc setup?
Saltman:
- Gerrit Loubser
- Current 4x4: None
All I can say is that my Patrol does not leak oil and the handbrake does not allow the car to roll back 0.5 m.
One good thing with the transmission brake is that if the Patrol is parked in 4wd with the handbrake on, you can not lift the back and tow it away.
- JohnBoyZA
- Site Admin
I don't know if mine just been set poorly, but my handbrake is not very effective....
- Stefan
- Nickname: Stefan
- Has thanked: 175 times
- Been thanked: 50 times
Dont' know abot 0.5m, but I found the movement of the car a little disconcerting as I've never before experienced this.
Other than not being able to tow the vehicle away when parked as Herrie described, what are the advantages/uses of a transmission handbrake?
