Pro-white 8J 16" rims
davejones
Full Name: David Jones
Nickname: David
Home Town: Lagos, Nigeria
Been thanked: 6 times
Post by davejones »
Looking for 4 or 5 to make black and use with the muddies !!
An ox, but with balls !!!
Freakazoid
Full Name: Pierre Becker
Nickname: Pierre
Home Town: Milnerton
Current 4x4: GQ
Re: Pro-white 7J 16" rims
Post by Freakazoid »
Why 7J, why not 8J?
If you cna get a set of Cruiser steel rims, they have the perfect offset for the GU.
JG Shields
Full Name: JG Shields
Nickname: JG
Post by JG Shields »
Try BURQUIP in Jet Park, Johannesburg. They supply all sizes PRO-WHITE rims. If they do not have the off-sett you require in stock, they will have it made. No need to bother with spacers.
I bought a new set of 16" rims for my trailer to match my car rims @ R285 (ex VAT) a piece some 16 months ago.
Patrol fan!
davejones
Nickname: David
Post by davejones »
Excuse the ignorance, but what is the difference between 7J and 8J ?
Thanks JG - just downloaded their APril 2010 price list... not so cheap anymore!!
Full Name: Gerrit Loubser
Nickname: Gerrit Loubser
Home Town: Richards Bay
Current 4x4: None
Been thanked: 11 times
Post by Gerrit Loubser »
The 7J rim has a nominal width between flanges (i.e. where the tyre mounts) of 7", while an 8J has a width of, yip, you guessed it 8". Every tyre has an allowable rim width range that is specified by the manufacturer. For instance, the BFG All Terrain T/A KO 265/75R16 can be fitted to rims in the width range 7' to 8" according to the manufacturers spec sheet, while the 285/75R16 version of that tyre needs rims in the range of 7.5" to 9".
The standard 16" diameter rims for the Patrols sold here was 8JJ-16, i.e. 8" wide, 16" diameter. The J and JJ specify different rim profiles. I believe the JJ profile is better at keeping the tyre from debeading at very low pressures.
JG Shields
Nickname: JG
Dankie Gerrit. Nou verstaan ek dit ook beter. Ek wou net iemand bel om meer hieroor uit te vind toe jou "post" deurtrek.
Patrol fan!
Russ Kellermann
Full Name: Russell Kellermann
Nickname: Russell Kellermann
2005 Patrol 4.2TD Wagon
Re: Pro-white 8J 16" rims
Post by Russ Kellermann »
Quite right about the rim width recommendation of 7.5 -9 , however, i purposefully ran my ran my 285's on 7 j rims with no problems at all to date.
