Stupid = Sweat, lots of Sweat.
Russ Kellermann
Full Name: Russell Kellermann
Nickname: Russell Kellermann
2005 Patrol 4.2TD Wagon
Post by Russ Kellermann »
So anyway, CT was covered in a blanket of cloud and drizzle today, and coming over Ou Kaap Se Weg was foggy as a Rusta's living room, so naturally, Lights on. Got to the other side, parked up and needless to say i left my lights on...came out,battery...DEAD! F.................ck. Considering i'd parked on what can only be described as flat ground,and with no one around to give me a jump, i new my task ahead would be a tough one. Ever tried pushing a patrol? Well i have, its heavy, flipping heavy. But i got it to a slight gradient which helped, and kicked it in 3rd, .....good to go!!! Never again, heaviest car ever i promise you! hahaha
G-MAN
Full Name: A.G.HOLMES
Nickname: G-MAN
Home Language: Engels
Been thanked: 9 times
Re: Stupid = Sweat, lots of Sweat.
Post by G-MAN »
That 2nd battery would have been sweet...! :wink:
Sucks Gas and Hauls Ass!
Russ Kellermann
:idea: now you got me thinking again! :idea:
Mammoth
Full Name: Johan Botha
Nickname: JB
Home Town: Roodepoort
Been thanked: 5 times
Post by Mammoth »
Hi, Happened to me in the past. Installed small practical headlight warning circuit. Makes big noise when the ignition is turned off while the lights are still on. I have attached small diagram. Hope u can view it.
2nd battery remains best option but space an issue.
JB
HL Warning.ppt
(21.5 KiB) Downloaded 395 times
JB
(Mammoth)
Sias
Full Name: Sias le Roux
Nickname: Sias
Home Town: Potchefstroom
Current 4x4: None (for now)
Post by Sias »
My GRX let's me know in no uncertain terms if the lights are still on with the ignition off.
weskus_surfer
Post by weskus_surfer »
@Russ: I feel your pain, as I've done the same too many times. Biggest worry would be doing that doer and gone on a west coast beach with no inclines.
@Mammoth: Thanks for the diagram!
GQ Patrol, 4.2D
Russ Kellermann
weskus_surfer wrote:Biggest worry would be doing that doer and gone on a west coast beach with no inclines.
Thats exactly what i thought about at that very point i was pushing the Troll,..scary thought!
Sias wrote:My GRX
Ja ja ja, rub it in!hahaha
Mammoth wrote: I have attached small diagram. Hope u can view it.
Mammoth you Legend, thanks man, i can see it and i will use your diagram to make my own within the next two weeks. very kind of you.
Mammoth
Nickname: JB
Post by Mammoth »
No Problem. only a pleasure!
I must admit that this circuit has one shortcoming. If you do want to have your lights on without a key in the ignition (For instance shedding light at night in a campsite)there is that constant beep that gets on your nerves. I once built a simmilar circuit that had a little bypass button. If I can find I will post it as well.
JB
(Mammoth)
OB1
Full Name: Obus Venter
Nickname: OB1
Current 4x4: Land Rover 110 Tdi Hard top
1997
Post by OB1 »
Who ever tried that trick of jacking it up? I read about it, never tried it.
You jack up one of the rear wheels, and fit a rope around it. Wind it a few times around so that it pulls tight. Switch on, put in third, na difflocks and handbrakes. Then yank really hard on the end of the rope. It should turn the wheel that will turn the motor over enough to puff into life, a bit like starting an old twostroke diesel motor. That is the theory annyway. Probably a good idea to chock the wheels...
AndriesS
Full Name: Andries
Nickname: None
Home Town: Pretoorsdorp
Has thanked: 28 times
Been thanked: 38 times
Post by AndriesS »
A proper use for the key in the ignition buzzer if you've disconnected it.
