Steering Damper
Russ Kellermann
Full Name: Russell Kellermann
Nickname: Russell Kellermann
2005 Patrol 4.2TD Wagon
Steering Damper
Post by Russ Kellermann »
Looking for a new steering damper, mine is kaput, .....i'm not keen on purchasing the likes of OME,IM,TJM,etc etc,...as i imagine they not gonna be cheap.My truck handles well even with my current one in bad condition so i cant see myself needing anything more than your run of the mill damper,...Any ideas what i should get and from where, also if you know estimated prices that would help me too.
Thanks boys.
Ps: out of interst, the ozzy boys all run hectic steering dampers (i imagine for the intability fed through the steering colmn associated with lifets more than 4 inches, but why do they have coil over shocks in there?
AndriesS
Full Name: Andries
Nickname: None
Home Town: Pretoorsdorp
Has thanked: 28 times
Been thanked: 38 times
Re: Steering Damper
Post by AndriesS »
I think the coil over sock assist more with a return to center portion. I like the idea of a adjustable damping unit which could be changed for tar or for dirt, maybe Konis have one that will suffice.
Check out a previous post of mine on steering dampers, I think Kagiso got one from the SupaQuick at a very reasonable price.
My 5 cents:
I have my opinions on some of the dampers sold by the big names, simple matching of length is not good enough for me.
I'm certain under normal conditions the Nissan part had better damping than the big name , even during operation the Nissan Part had better damping.
I'm also curious as to the working of a damper that was designed to work upright that need to work on it's side now.
Russ Kellermann
Re: Steering Damper
You reckon a normal Gabrial Safari or Gas Magnum will do the trick? i'll pay the auto spare shops a visit tomorrow. Ps: how much does a OME/TJM/IM etc go for? R???
Abri Hoffman
Full Name: Abri Hoffman
Nickname: Abri
Home Town: Monument Park
Current 4x4: 2013 FJ Cruiser
Been thanked: 7 times
Re: Steering Damper
Post by Abri Hoffman »
Phoned Steve at Koni yesterday. Apparently Koni does not offer a steering damper. Pitty as I am in the market for one as well.
2013 FJ Cruiser
"Jack Russel"
Russ Kellermann
Re: Steering Damper
Abri, i'll call around and let you know asap ok. However, as i said, i dont think i'm gonna go for a truly expensive one, jjst a middle of the range i think. keep you posted.
Mayhem
Full Name: Dennis Maytom
Nickname: Mayhem
Home Town: Cape Town
Current 4x4: Nissan Patrol GU 4.2 Turbo Intercooled (sold)
Nissan Patrol GQ SWB(for sale)
Re: Steering Damper
Post by Mayhem »
An OME steerind damper costs R 1703.94 full retail VAT inc.It is defiantly better than any factory or after market unit from your local supplier.
1996 SWB GQ Patrol TD42 Turbo intercooled (150kw/600Nm) (Destroyed in Outback 2008)
2000 GU with TD42 out of GQ (sold)
Hadrbody/Patrol, LS6 Chev V8 (420 HP), Hummer auto box on 36' Iroc Tyres
Russ Kellermann
Re: Steering Damper
ok , i didnt get too far with solving this yet, and midas certainly dont keep patrol dampers of any make. will try other outlets soon as. Another thing, i'm acquiring more and more interest with regard to the RTC damper. What benefit would this produce over traditional damper? your thoughts please? Perhaps the boys find it eliminates death wobble ?
Russ Kellermann
Re: Steering Damper
Mayhem wrote:An OME steerind damper costs R 1703.94 full retail VAT inc.It is defiantly better than any factory or after market unit from your local supplier.
Sorry Mayhem, only saw your post after my last one. your opinion is noted and i must decide weather its worth the extra tom closer to the time i guess, thenks for adding in the costs there too, puts things into perspective quickly and saved me a phone call. cheers mate.
Russ
