Extra fuel transport
Has thanked: 1134 times
Been thanked: 1044 times
If you drive a petrol Patrol, you often need more fuel than the tanks can take.
I still maintain that the best solution technically is a set of long-range tanks, but these are either expensive or unreliable or sometimes both.
Obviously fuel inside the vehicle comes with it's own set of drawbacks/dangers.
The other common alternatives are the roof rack or a rear swing-arm. Both place the extra weight at the most disadvantageuos position from a centre of gravity point of view.
So what do you guys think of this:
ChristoSlang
Nickname: ChristoSlang
Home Town: Pretoria, ZA
Has thanked: 29 times
Been thanked: 136 times
Re: Extra fuel transport
Post by ChristoSlang »
I like! Lower than on the roof rack, further to the front than on a rear swing-arm. Maybe the Landy guys know a thing or two?
PS: Gaan nie werk vir Tijmen nie, hy sal nie sommer sy warm stort opgee nie...
Christo (the snake man)
Arnolg
Full Name: Arno le Grand
Nickname: Arno
Current 4x4: 2006 4.8 GRX Auto
Has thanked: 21 times
Been thanked: 34 times
Post by Arnolg »
I was also thinking about this while we were on the river trip and I started to get anxious about the fuel gauge dropping faster than Willie le Roux dropped a rugby ball.
My idea was similar to this, but I was also wondering how this could work with less wind resistance for long drives at higher speed.
That back window is mostly useless, so I was thinking of replacing it with a plate that's indented to the inside.
This way, you could theoretically have the entire window sill carry the weight of the jerry-can without having to rely on the roof sill (I'm not sure if this is better or worse).
The advantage here is that ideally, you only have half the jerry-can protruding on the outside and the other half "inside" the body.
Something like this
But of course without the opening flap and more formed to fit a jerry-can.
Is it a very bad idea to carry jerry-cans sideways if they don't fit vertically?
Not a bad idea to carry them on their sides although I think they leak a little more.
The problem is making that thing seal. Several guys have tried making gull-wings for the Y61 locally, without too much success that I have seen.
By the way, mine carries the weight both top and bottom, although it does require drilling some holes in the body.
Pretty sure this has less wind resistance than a roof rack, and probably similar to jerry cans on a roof rack? Not an aero expert.
Anthony Forgey
Full Name: Anthony Forgey
Nickname: Anthony
Home Town: Randburg
Has thanked: 179 times
Been thanked: 206 times
Post by Anthony Forgey »
PC I think it's a great idea!
Thank you Sir.
ra_01
Full Name: Rahul
Nickname: Rahul
Current 4x4: Patrol 4.8 2016
Has thanked: 23 times
Been thanked: 60 times
Post by ra_01 »
Hi Peter its a good idea to install jerry cans mounts on the side. Defender guys does it.
I used frontrunner sometime ago and its a good alternative to store fuel.
Rahul
Current Straight 6 :wink:
