Hi guys,
Some unfortunate fire started in the engine compartment because of an enclosure pipe that came loose and fell onto the engine. Electrical wires burned and a whole through the throttle body sensor. Apparently the complete body needs replacement.
Anyone that maybe have a spare 2003 Y61 4.8 throttle body? If there's any information about a different solution, that'll also be super helpful, thanks!
Part # 16119VC21A
Throttle Body Needed
- Full Name: Jakes Louw
- Nickname: Jakes
- Home Town: De Wildt
- Current 4x4: Jeep Wrangler
- Has thanked: 28 times
- Been thanked: 29 times
Re: Throttle Body Needed
A quick check shows that the Hitachi 16119-VC21 was used in various Nissan Patrols. The suffix (A to D) was just for internal reasons, the TB stayed the same from 1997-2007 as far as I can see.
Also sold as the Hitachi Pierburg RMB7002(A-D).
So basically a 70mm throttle body with mechanical cable activation and a resistor based throttle position sensor.
Prices are hectic. I suggest you talk to Tinus Lotz or similar. Maybe Jap Auto has some?
- ChristoSlang
- Nickname: ChristoSlang
- Home Town: Pretoria, ZA
- Has thanked: 29 times
- Been thanked: 137 times
Zak, you should also contact David Volschenk who has a Patrol/Safari scrapyard.
His phone reception is dodgy, send him a WhatsApp @ Oh ate three - four double nine - 1588.
BCX greetings...
BCX greetings...
- Zakhil
- Full Name: Zak Cronje
- Nickname: Zakhil
- Home Town: Gouritsmond
- Current 4x4: 1983 Datsun Safari
2003 Nissan Patrol 4.8 - Home Language: Afrikaans
- Has thanked: 25 times
- Been thanked: 7 times
Thanks Jakes, that's some really helpful info. Will have a look if I can find something like that.
Christo! Not everyday I connect with BCX guys on here, hope all good! Did contact David and he has one for R10k. In that case I'd rather go for PartSouq with R12k new body.
- Nickname: Jakes
- Full Name: Fanus
- Has thanked: 249 times
- Been thanked: 219 times
I use to work for BCX many moons ago... left IT for a retail opportunity in 2005...sometimes wonder how it would have ended up for me if I stayed in IT...
- Nickname: Jakes
IT isn't what it was 20 years ago. It's a cut-throat industry now with very little honour and loyalty.
