Cooked Ignition Coils
- Full Name: Wilfred Moore
- Nickname: Wilfred
- Current 4x4: 2010 Nissan Patrol 4800 GRX
- Been thanked: 4 times
I recently visited the Kruger Park. While driving, very hot day, I went through a small puddle of mud water. Shortly after, the engine warning light came on and the Patrol died on me. Trying to start it again with difficulty, the Patrol was misfiring badly. Drove to the nearest camp site, where I had the Patrol recovered on a flatbed back to Pretoria. After investigation, it was found that 4 of the 6 ignition coils were cooked. ( photos attached)
What could be the reason?
In the mean time, Thys fitted other coils and the Patrol runs perfectly.
- Full Name: Jakes Louw
- Nickname: Jakes
- Home Town: De Wildt
- Current 4x4: Jeep Wrangler
- Has thanked: 28 times
- Been thanked: 28 times
Re: Cooked Ignition Coils
I'm no expert, but I'd say a combination of age and the water on a hot coil or water on the voltage supply to the coils.
That's why one should only buy TD42 patrols or ZD30 if your name is Reenen.
- Has thanked: 60 times
- Been thanked: 255 times
I did not know this was a risk for coils.
Wilfred, do you think the "puddle of mud water" could have had that effect? I.e. splashed all the way to the top of the engine, to coils?
- Nickname: Jakes
As far as I know, a short from coil to earth can cause a coil to melt. So in this case, the high voltage went to the head via the side casing, not through the plug.
Path of least resistance.
- Nickname: Wilfred
Hi Alex, could not see anything on the coils, there were splash marks on top of the engine and under the engine cover, not much though.
- Nickname: Jakes
Were the plugs changed recently and are they correct for the coil spec?Wilfred Moore wrote: ↑09 Jan 2024 11:49
Hi Alex, could not see anything on the coils, there were splash marks on top of the engine and under the engine cover, not much though.![]()
Coils will fail if the voltage can't get out of the plug. More than one coil at a time implies a common issue. The only common issue is the upstream voltage (from the voltage regulator) or the downstream circuit : in this case, since this is a coil-on-plug, the plugs are the only common items.
- Nickname: Wilfred
Hi Jakes, thanks for your response. I had long life sparkplugs fitted, which was in the vehicle for probably 2+ years, they said it should be changed every 90,000 Km. Thys Ellis has now changed the plugs with normal plugs when fitted the new coils.jakeslouw wrote: ↑09 Jan 2024 12:12Were the plugs changed recently and are they correct for the coil spec?Wilfred Moore wrote: ↑09 Jan 2024 11:49
- Nickname: Jakes
NGK PLFR5A-11 or LFR5A-11 as per OEM? As far as I can see, you MUST run a resistor-type plug.Wilfred Moore wrote: ↑09 Jan 2024 16:02
- ChristoSlang
- Nickname: ChristoSlang
- Home Town: Pretoria, ZA
- Has thanked: 27 times
- Been thanked: 136 times
Makes sense: melting comes from heat, heat comes from excessive current, excessive current comes from low resistance or a short.
- Nickname: Wilfred
The plugs that were in my vehicle: LFR5AP-11 (NGK R)jakeslouw wrote: ↑09 Jan 2024 16:19NGK PLFR5A-11 or LFR5A-11 as per OEM? As far as I can see, you MUST run a resistor-type plug.Wilfred Moore wrote: ↑09 Jan 2024 16:02
