Afternoon All, Ive got a GQ 60 fitted with TB 42 E EFI motor and I'm looking for a O2 sensor. I believe the single wire sensor from a TB45 is the same.
Does anyone have a TB45 motor lying around with one fitted I can buy?
I managed to get one from David V but it was for the TB 4.8 with 3 wires. - If anyone needs a 3 wire one, drop me a PM.
Thanx
Ernie
O2 Sensor
- Tunja
- Full Name: Ernest Tunnah
- Nickname: Tunja
- Home Town: Swakopmund
- Current 4x4: 97 Patrol TD 4.2 Manual TS
11 BMW X5 Auto 8 speed -Swambo - Home Language: English
- Has thanked: 9 times
- Been thanked: 18 times
O2 Sensor
- iandvl
- Full Name: Ian de Villiers
- Nickname: Ian
- Home Town: Garsfontein
- Has thanked: 451 times
- Been thanked: 719 times
Re: O2 Sensor
Is this the MAF sensor ? Or something else ? Where does it fit on the motor ? I have a TB45 lying around at home and will be able to check.
Edit: Did a bit of research, and presume this is the sensor in the exhaust manifold ? If so, apparently generic Bosch part (0258986501) should sort you.
- Tunja
- Nickname: Tunja
Re: O2 Sensor
Hi Ian, yes its the one in the exhaust manifold.
I did ask Bosch here in Swakopmund but they didn't seem very interested in trying to find one - I didn't have a part # then. so will try again.
If not would appreciate if you can have had a look if you have one.
Thanx
Ernie
Thanx
Ernie
