Tire pressure check magodi
Re: Tire pressure theck magodi
The biggest down fall of external one is once you remove the cap you cant see the pressure. ..when defating and putting air back you can follow it all the time
:mytwocents:
TonyP
Junior Member
Junior Member
Full Name: Tony Page
Nickname: Tony
Has thanked: 1 time
Re: Tire pressure check magodi
Post by TonyP »
Is it still possible to order one of these systems for my 4.8
jonathan
Full Name: Jonathan Venter
Nickname: jonathan
Home Town: Jacobsbaai
Current 4x4: 2005 4.8 GRX
Has thanked: 9 times
Been thanked: 43 times
Post by jonathan »
When fitting my new tekkies I also installed this pressure monitoring system:
Bluetooth Pressure monitor
I installed the internal sensors and my plan was to link the Bluetooth monitor to my Android radio/GPS, but for some reason it does not pair :think: . Works perfectly on my phone though. Price is fair and more or less on par with what is available these days (about R3500).
Unfortunately it doesn't have an off-road function, but you can set all the limits on your phone when using the app.
OEBIE
Junior Member
Junior Member
Full Name: SOULBY KITCHING JACKSON
Nickname: OEBIE
Home Town: KIMBERLEY
Current 4x4: PATROL GRX 4.8
Post by OEBIE »
Hi! Has anybody had experience with the 6 Wheel Solar Tyre Pressure Monitoring System - Internal Sensors TPMS? It is sold by Tyre Care via Takealot and costs R2990.00. How accurate and reliable is it? Looks like the ideal TPMS for towing. :thumbup:
Haai julle gaan weer n bulk order doen wie stel belang?
[ Hi Tinus, as julle 5 of meer eenhede bestel dan kan ons op die volgende prysse werk. Ek het R25 vir koerier dan by elke eenheid ingesluit. Ek hoop dit is genoeg!
4 Sensor Internal TPMS - R1775
6 Sensor Internal TPMS - R2250
Ekstra External Sensor los - R475
roelf prinsloo
Full Name: Roelf Prinsloo
Nickname: Roelf
Home Town: Klerksdorp
Current 4x4: Nissan Patrol 5.6L V8 LE Premuim ( Y62 ) 2018
Has thanked: 17 times
Been thanked: 17 times
Post by roelf prinsloo »
Ek stel moontlik belang in 2 stelle. Kan ek meer inligting oor dit kry en foto. Ek kry nie die digityre draad nie .Sal dit baie wardeer.
