Tire pressure check magodi
Re: Tire pressure theck magodi
Alex they are all cool just need the one that goes inside the tire i ordered some for a friend the other day from sa company will try post link here
andredurand
Full Name: andre durand
Nickname: leeuloop
Current 4x4: PATHFINDER
Home Language: afr
Been thanked: 37 times
Post by andredurand »
Alex ek het ook een in my Patrol en dit werk baie goed
Andre Durand
Nissan Hardbody 3.3 sold
Nissan patrol 4.5 sold
Nissan parthfinder 2,5 sold
Nissan navara 4l v6 4x4
Andre daai is die wat ons gekoop het op e bay hulle is great
Ek het een op Tinus se aanbeveling by Marius Bijker gekoop. Werk uitstekend en gee ook die altenator voltage. Help dus ook om die altenator te monitor. Weet nie of Marius die monitors nogsteeds verkoop nie. Miskien kan Tinus help in die opsig.
stobi_de
Full Name: Frank Stober
Nickname: stobi_de
Home Town: 51647 Gummersbach - Germany
Current 4x4: Nissan Patrol GR2 /Y61 (TBE45) from 1999, short Nissan Patrol GR1 (2.8 TD) from 1992, Volvo XC60 AWD
Home Language: German
Has thanked: 9 times
Been thanked: 28 times
Post by stobi_de »
Have this system in Germany and in Africa, working perfect with tube or tubeless.
Extremely simple installation!
http://www.tiremoni.co.uk/
Brought the same to my friend in Bethlehem for his Landcruiser and a different one for his motorbike.
Chris Skinner
Full Name: Chris Skinner
Nickname: Chris
Has thanked: 10 times
Been thanked: 53 times
Post by Chris Skinner »
Problem with this system is that the caps get stolen (in this country anyway!)
Much better to have the internal one in my view.
stobi_de
Nickname: stobi_de
Post by stobi_de »
Hm, have them since 5 years. Even in Nairobi not stolen.
It is possible to lock them with a small allan key, but thats not very usefull.
With the internals you can't drive tube-tires and I heard that the mounting and balancing of new tires is very expensive.
It's true that you can't use them on tubed tires.
It's also true that some tire shops are worried about damaging them, but it doesn't involve any more work to mount and balance tires and therefore shouldn't cost more.
Several people I know have lost external ones, either through falling off due to vibration, through damage in off-road conditions or through theft.
The biggest down fall of external one is once you remove the cap you cant see the pressure. ..when defating and putting air back you can follow it all the time
:mytwocents:
