1999's Alarm Remote Replacement
Re: 1999's Alarm Remote Replacement
I have a problem with mine as well - is heat up and the plastic melt - I think the connection is not properly and I tried to fix it and will see if it is fixed now.
Florian320
Full Name: Florian M.
Nickname: Flo
Home Town: Hoedspruit
Current 4x4: '99 GRX 4500
Home Language: German
Has thanked: 42 times
Been thanked: 34 times
Post by Florian320 »
Hi Herrie,
that is great, thanks!
Can you just give me a hint where I can find that box? The last time I had a look I didn't see it :redface:
Edit: if I have a look in the Y61 technical manual, on page EL 260 there is a 'super lock control unit' - is that the one I am looking for?
Theoretically that would be the only item I have to exchange if I wanted to get a new remote lock system, isn't it? Or must I look for the multi remote control unit I can see on page EL 330?
Bruin Beer
Full Name: Riaan Delport
Nickname: Rooian
Been thanked: 21 times
Post by Bruin Beer »
Herrie,
I would install a nice thick wire from the connector pins going through the PCB to the other end of the copper track running on the PCB.
What you also need to verify is that you might be having a bad crimp on the mating connector (wire side) that is generating the heat which gets transferred through the pin in the picture.
On such a high current interface you need to confirm both sides.
Bruin Beer
Hi Florian,
You just have to take the panel right side of you petrol pedal out and if you loosen that rubber that seal you door you will find the wire for the remote signal and that wire is connected to that unit and you will find it then.
Florian320
Nickname: Flo
Thanks Herrie, I will have a look soon!
Some more photos:
Florian320
Nickname: Flo
Thanks Herrie! With that even I should find it - but: I had that panel already removed and at least couldn't read any conlog-sticker on any box. But I will try again and report.
Best regards and thank you again!
Florian
Florian320
Nickname: Flo
Ok, now I did the big solution: I went to the auto electrician and had a new alarm system installed, an Autowatch 446LRi.
I just wonder why every electrician seems to be a legal stealer: he took 4900 ZAR away from me for that!
