My 4.5 GU officially a 4.2 Diesel now
Re: My 4.5 GU soon to be a 4.2 Diesel
Die vraag is wanneer kan hy dougnuts maak :blonde:
Seandp
Full Name: Sean Du Plessis
Nickname: Sean
Current 4x4: Suzuki sj 410(toy)
Gu Patrol 4.2tdi GRX (Also on the smokers team now)
Has thanked: 9 times
Been thanked: 60 times
Post by Seandp »
Hahahaha ons sal moet plan maak die week ek moet seker een of ander tyd daai 35's inloop
Lyk goed!
Seandp
Nickname: Sean
Post by Seandp »
Dankie Peter Ry jou lorrie al was vrydag so vinnig by Micheal in om parte op te laai toe sien ek hulle is besig om hard te werk an jou masjien
Plaas jy gegroet het, ek was self daar aan die werk.
Hy het vrydagaand op eie stoom by Ant's Custom Shop uitgekom, maar die enjin gaan weer moet uit. Clutch gly...
Seandp
Nickname: Sean
Post by Seandp »
Haha Sal in die vervolg almal ordentlik groet ek was so bietjie aan die haastig kant moes nog Jet Park toe gaan om silicone bends op te laai. Maar dis goeie nuus as hy darem aan die ry is en dis darem een ding wat ek agter gekom oor die paar jaar wat ek karre bou jy sal nooit ophou werk aan hulle nie daar sal altyd iets wees wat nie reg is nie of wat jy wil verander dis soos om kinders groot te maak daar is altyd iets wat moet gebeur. :woo: :woo:
Seandp
Nickname: Sean
Post by Seandp »
So today was a busy day finished the donaldson's brackets and the pipe work for it.Tomorrow it needs to be stripped down again to get powder coated and then it needs to be put back together.And then i made up some stainless water pipes for top and bottom.Still needs some final welding but will get it sorted out tomorrow.But first need to make my welding machine's regulator to a dual regulator to back purge my stainless from the inside other wise the start to rust from the inside out.
Seandp
Nickname: Sean
Post by Seandp »
So after a long week of hard work i can finally tell you all that i am officially a koolstoof smoker.My lorrie is finished and running quite lekker i still have some electrical issues to sort out like the main fuel guage is stuck don't know why but the sub tank is working fine and for some reason the speedo is not working but the Km reading work fine.I will post some photos tomorrow.
:bravo:
:bravo:
