Diff-lock Trouble
RTP
Full Name: Richard Poalses
Nickname: RTP
Home Town: Boksburg
Has thanked: 7 times
Re: Diff-lock Trouble
Post by RTP »
Hi Guys
so after my Patrol went back to Nissan and they sent the car to Rex Gearbox and Diff . I waited 4 week to get it back and they have fix it my diff lock is working , they say they replace the switching valve under the bonnet. I am nit sure how this solved the problem as I switch the pipes around and the diff-lock still did not work ..
Never the less they have fix it and I am happy ..
I am not to sure what this valve costs but it may be worth changing it to see if the make any difference. They told me the value was faulty and it did not give enough suction to the actuator on the diff there for not enough pressure to push the gear into place.
Hope this helps ..
RTP
Rhett
Nickname: Rhett
Home Town: Heidelberg
Has thanked: 163 times
Been thanked: 78 times
Post by Rhett »
Thanks for the feedback, it is definitely worth a look. I still have not had time to check mine out, but this weekend seems pretty free.
By "switching valve" I'm assuming they mean the vacuum solenoid in the engine compartment? Anyone able to confirm?
Rhett
Nissan Patrol 4.8 GRX
Toyota Land Cruiser HJ45
Picasso
Full Name: HS
Nickname: Picasso
Current 4x4: Nissan Patrol
T3 Syncro
Home Language: German
Has thanked: 10 times
Been thanked: 44 times
Post by Picasso »
Hallo Rhett,
The "switching valve" can only be the vacuum solenoid.... which would be situated at the left hand / top of the firewall. I have one spare unit which I could give you for "fault finding purposes".
:salute:
Has thanked: 189 times
Been thanked: 270 times
Rhett wrote:Thanks for the feedback, it is definitely worth a look. I still have not had time to check mine out, but this weekend seems pretty free.
That is pretty depressing - a free weekend and you are not joining as at Moegatle :surprised:
Wilkie
Full Name: Errol Wilken
Nickname: Wilkie
2004 BMW 3.0D X5
Post by Wilkie »
YYess and you would have all the GURU'S there to assist if you had problems with diff lock :oldtimer: :oldtimer:
Rhett
Nickname: Rhett
Post by Rhett »
I know, I know :doh:
I did have a productive day around the garage though...
Hope you guys are enjoying!
Rhett
