222K Overlanding Parts Kit
Anthony Forgey
Full Name: Anthony Forgey
Nickname: Anthony
Home Town: Randburg
Has thanked: 179 times
Been thanked: 206 times
Re: 222K Overlanding Parts Kit
Post by Anthony Forgey »
Jannie
I wouldn't get most of the stuff from Nissan, but I would get the nissan viscous hub, water pump and thermostat.
for belts:
Just go to the local parts store and get the belts (Dunlop makes them so do a number of other manufacturers)
For the water hoses get the kit from TerrainTamer. it includes all of the little hoses on the 4.8
Alternator and starters - shop around for aftermarket units. PM me if you need help
Fuel Pump:
use the bosch unit. its basically a direct fit.
for the vacuum hoses , just buy 4mm vacuum hose off the roll. you cant just use any hose here, it must be for vacuum.
jan.dup
Full Name: Jannie Du Plessis
Nickname: Jannie
Home Town: Hermanus
Current 4x4: Patrol 4.8 GRX
Has thanked: 30 times
Been thanked: 13 times
Post by jan.dup »
I took the Patrol to Frans (Tour de Frans) for a thorough checkup and fitment/refurbish of all necessary (although some not faulty yet) parts. I took it for a 4700km test drive :wink: and all went smooth and I am hugely impressed with Frans's professionalism and willingness to help with whatever is being asked from him. A big thanks to Frans :thumbup:
Hopefully now for another 200 000 hassle-free km of pleasure :salute:
Mal Hannes
Full Name: Hannes Wessels
Nickname: Hannes
Home Town: Roodepoort
Has thanked: 26 times
Been thanked: 26 times
Post by Mal Hannes »
Hi that sounds awesome would you mind sharing what you did in the end.
Also how much it cost.
Spike
Full Name: Spike Pretorius
Nickname: Spike
Home Town: Milnerton
Home Language: Sleg soutpiel
Has thanked: 77 times
Been thanked: 87 times
Post by Spike »
If you bother carrying a spare starter with you I suggest also getting the tools to fit it. Starter replacement on a patrol is a really tedious process needing extra hands with extra wrists on them. A swivel joint for your socket spanner set is a must
:oldtimer:
Sardonic Fattist
izakjbrt
Full Name: Izak Joubert
Nickname: Izak
Home Town: Ramsgate
2012 Patrol 4.8 GRX (MA-trol)
Has thanked: 235 times
Post by izakjbrt »
Spike wrote: 04 Dec 2020 07:20 If you bother carrying a spare starter with you I suggest also getting the tools to fit it. Starter replacement on a patrol is a really tedious process needing extra hands with extra wrists on them. A swivel joint for your socket spanner set is a must
Agreed
The starter sits on the kakkest spot. Carry a hammer with you, sometimes just hitting the starter with a hammer give it that last bit of juice for you to get the car going
2007 Nissan Patrol 4.8 grx
jan.dup
Nickname: Jannie
Home Town: Hermanus
Post by jan.dup »
Sorry for the late reply Hannes, but it's a bit hectic from when I came back from the trip.
Frans has a 68/72 point checklist when he inspects your Patrol. What was done in the end was:
A full service - Oil change, Oil-, Air- and Fuel filter changed etc
Long life Sparkplugs
All fanbelts replaced
Difflock vacuum selenoid hoses cleaned
A difflock filter was installed
All hoses replaced (Terrain Tamer)
Suspension bushes
Front and back Radius arms bushes replaced
Front and back Panhard Rod bushes replaced
Starter/Alternator recon
Viscous recon
Front wheel bearing play adjusted
Total cost was +- R 23 000
What was done previously at about 180 000km
Wheel bearings replaced
Manual hubs fitted
Radiator replaced
Replaced the Exhaust system while the Patrol was with Frans.
Also to mention to check the engine and gearbox mountings.
