Sal bietjie met Thys gesels.
Baue dankie
Tb45 Distributor
- Junior Member
- Full Name: Herman Louw
- Nickname: Harry
- Home Town: Hennenman
- Current 4x4: 2000 Nissan Patrol 4.5 GRX
- Been thanked: 1 time
- David M
- Full Name: David Marais
- Nickname: David Marais
- Home Town: Midrand
- Has thanked: 20 times
- Been thanked: 97 times
Re: Tb45 Distributor
Partsouq has it on their catalogue but no stock for years and about the same price as Nissan SA.Tinus lotz wrote: ↑02 Jun 2020 14:55 thys ellis knows his stuff but sure you can get a working dizzy from david or order one online partsouq .com
- Full Name: andre durand
- Nickname: leeuloop
- Home Town: Alberton
- Current 4x4: PATHFINDER
- Home Language: afr
- Been thanked: 37 times
Daar is C.Reynolds cel no2824421902 hy maak distribtors reg is in Germiston
Andre Durand
Nissan Hardbody 3.3 sold
Nissan patrol 4.5 sold
Nissan parthfinder 2,5 sold
Nissan navara 4l v6 4x4
- Full Name: Fanus
- Has thanked: 247 times
- Been thanked: 219 times
To go this route with a tb42 what would it entail?
Pros & cons, cost?
- Has thanked: 1136 times
- Been thanked: 1047 times
Very easy job. Cost is just over R2k for parts, and to do it will take about an hour for guys like as and about 15 minutes for an experienced auto-,electrician.
Buy the module crom Bruce at Offshore Marine Services in Cape Town.
Pro is that you don't need to replace and adjust points at every service, and ignition timing will stay basically where you left it.
Cons are the cost and a slight fragility to electrical ham-handedness in the engine bay. If you are fiddling with connecting and disconnecting stuff and you get the order wrong you may create a short that blows the unit.
But it's not a magic wand. It reduces the error from a worn distributor but doesn't fix it 100% and it doesn't help if the problem is an issue with the advance mechanism.
