jacquesW
Posts: 52 Joined: 28 Nov 2017 09:51
Full Name: Jacques Wilkinson
Nickname: JacquesW
Home Town: Kraaifontein
Has thanked: 8 times
Been thanked: 14 times
Post
by jacquesW » 21 Aug 2018 11:09
Thanks for those PICS. Yeah if that is how it is holding up in a loadbin then I am confident it will hold for the application I am going for.
Will post PICS when I get started. Just not sure when I will eventually get to kick off this little project. Day jobs are over rated
Craig Lord
Posts: 217 Joined: 24 Jun 2018 08:21
Full Name: Craig Lord
Nickname: Craig
Home Town: Tuli Block
Has thanked: 97 times
Been thanked: 60 times
Post
by Craig Lord » 08 Sep 2018 10:13
Has anyone considered using Super lakold? You can get 20L for R750 from build it and as far as I know you can paint metals as its non corrosive. I cut and old wine barrel in half and painted the inside of each half with super laykold to make them water tight so they could be used as extra large ice buckets. Painted 3 coats and it was very very thick by then. It's a rubberized waterproofer and the finish is very similar to bakkie liner ...
When in doubt throttle out !
4.8 GRX Patrol (sold)
Posts: 2053 Joined: 21 Oct 2014 21:01
Current 4x4: THE PATROL COLLECTION 2004 4.8 GRX TURBO "Tinkerbell" 2003 TD42T GRX "The Coal Roller"
Has thanked: 211 times
Been thanked: 218 times
Post
by hugejp » 08 Sep 2018 10:42
Intetesting.
How does it hold up to UV?
Craig Lord
Nickname: Craig
Post
by Craig Lord » 08 Sep 2018 10:53
I can't say for sure but it states that one of its primary uses is a waterproof roofing sealant that can be used on flat roofs and corrugated roof sheets so it should be pretty good...
jacquesW
Nickname: JacquesW
Post
by jacquesW » 08 Sep 2018 11:10
Got started with the project. Front fenders also had broken clips so going to make them bolt-on now. Some progress PICS
Craig Lord
Nickname: Craig
Post
by Craig Lord » 08 Sep 2018 11:17
I like the look of the finish on those fenders.. looking forward to seeing them back on your vehicle
Post
by hugejp » 08 Sep 2018 15:42
Nice work Jacques!
Can you show your new attachment solution for the fenders pls.
jacquesW
Nickname: JacquesW
Post
by jacquesW » 09 Sep 2018 06:45
Thanks Guys. Yeah thus far I am pretty chuffed with the result. I will post some more closeup pics when I get to refitting the fenders to show the attachments solution. It might only be in a little while. The project is running in a "bietjie hier, bietjie daar" format as time allows, so it's taking time. I still have some other polyurethane bits to do on the car as well before re-assembly..
jacquesW
Nickname: JacquesW
Post
by jacquesW » 25 Sep 2018 08:35
All the panels back on the car. Still got some touch ups here an there to do but happy with the end result. Now it is for the test of time.
