Wilkie
Posts: 1402 Joined: 24 Feb 2014 15:33
Full Name: Errol Wilken
Nickname: Wilkie
Current 4x4: 1999 4.5 GRX Nissan Patrol 2004 BMW 3.0D X5
Has thanked: 69 times
Been thanked: 92 times
Post
by Wilkie » 28 Oct 2016 20:59
Fanus jy moet breër spaar wiel opsit dan gaan die deur nie squeek nie
Posts: 3351 Joined: 23 Nov 2014 14:20
Has thanked: 243 times
Been thanked: 208 times
Post
by SJC » 28 Oct 2016 22:46
Sal dan maar die hilift jack opsit..
Posts: 7590 Joined: 29 Aug 2010 13:07
Current 4x4: Nissan patrol 4.8 GRX 2005 Toyota 2.7 legend 35 LWB 4X4
Has thanked: 802 times
Been thanked: 562 times
Post
by Tinus lotz » 31 Oct 2016 06:17
Jis wilkie jy is slim..daai dun bande weeg mos niks nie
Wilkie
Nickname: Wilkie
Post
by Wilkie » 31 Oct 2016 08:46
Net so
Post
by SJC » 31 Oct 2016 10:33
Tinus lotz wrote: Jis wilkie jy is slim..daai dun bande weeg mos niks nie
Wilkie wrote: Net so
hmmm, ja.
Cooper ST Maxx 255/85r16 = 53lbs / 24.04kg
Cooper St Maxx 285/75r16 = 55lbs / 24.95kg
P.S> ek sien 265/75r16 weeg slegs 49lbs / 22.23kg (heelwat minder rubber as 255/85r16....)
JoshJ
Posts: 986 Joined: 30 Nov 2013 16:16
Full Name: Joshua Joubert
Nickname: Joshua
Home Town: Centurion, Gauteng
Current 4x4: 2004 GL TD42
Has thanked: 81 times
Been thanked: 96 times
Post
by JoshJ » 01 Nov 2016 14:52
When mine was still fresh from the showroom floor it also rattled when driving gravel. The door light would flash. I also adjusted the locks. Solfed the problem. But I knew overtime with that wheel on the door, the hinges will wear out quicker. Hence when i build my bumper. The main purpose was to get the wheel of the door. So hopefully it will safe it from where for an extra few years..
Fanus, try replacing the door stopper rubbers. They are there to put tension on the door. Thus preventing execive rubbing.
Being alive is a Blessing!!
Joshua
TijmenvdS
Posts: 307 Joined: 23 Nov 2016 06:25
Nickname: Tijmen
Current 4x4: 1997 Patrol TD42 GQ ST Chevrolet 1974 K10 402 V8
Has thanked: 32 times
Been thanked: 106 times
Post
by TijmenvdS » 03 Dec 2016 20:06
Op die boonste hak in die middel teen nie dak is daar twee spacer plaatjies. Ek het myne uitgehaal. Die deur maak baie stuiwer toe en trêk homself bietjie op. Ek het nogi weer getoets nie maar wonder net of een van julle dit al gedoen het en werk dit.
Posts: 2053 Joined: 21 Oct 2014 21:01
Current 4x4: THE PATROL COLLECTION 2004 4.8 GRX TURBO "Tinkerbell" 2003 TD42T GRX "The Coal Roller"
Has thanked: 211 times
Been thanked: 218 times
Post
by hugejp » 05 Dec 2016 09:29
TijmenvdS wrote: Op die boonste hak in die middel teen nie dak is daar twee spacer plaatjies. Ek het myne uitgehaal. Die deur maak baie stuiwer toe en trêk homself bietjie op. Ek het nogi weer getoets nie maar wonder net of een van julle dit al gedoen het en werk dit.
Het jy fotos van die plaatjies?? Sal graag wil sien...
Post
by SJC » 08 Dec 2016 17:25
Post
by hugejp » 08 Dec 2016 19:54
Baie Dankie!!
