ZD30-DI changes to ZD30-CRD
- Full Name: Errol Wilken
- Nickname: Wilkie
- Has thanked: 69 times
- Been thanked: 92 times
Re: ZD30-DI changes to ZD30-CRD
is nogal waar Tinus ,maar hoe lank hou n ding as hy tot op die limit moet operate om saam regte lorries te hardloop
Ek het nou op die auz forum gekyk....manne roer die 30l crd motors hulle is baie met meer as 300000 km en niks moeilikeid nie......ek moet se dit lyk goed....
- Nickname: Wilkie
Dis goeie nuus ,en ek wens elke diesel fan net lekker ry toe .....veral in n Patrol !!!!!
- JoshJ
- Full Name: Joshua Joubert
- Nickname: Joshua
- Current 4x4: 2004 GL TD42
- Has thanked: 81 times
- Been thanked: 96 times
Dis die beste way om te roll, in Diesel Patrol
Being alive is a Blessing!!
Joshua
Joshua
- jonathan
- Full Name: Jonathan Venter
- Nickname: jonathan
- Home Town: Jacobsbaai
- Current 4x4: 2005 4.8 GRX
- Has thanked: 9 times
- Been thanked: 43 times
Josh maybe you can help me out here - I am keeping an eye out for a 4.8 in a price and year model that would suit me, but I've also noticed a few diesels. So after your post I've been trying to check which motors they have. Does the 3.0l pick-up have the same motor as the stationwagon? Because I've noticed the below 2012 stationwagon with which appears to be the DI engine not the CRD,
Did the changes only come later, or did they change from one to another then back again?
and then this 2015 pick-up with what looks like the CRD.
So I am confused
- JoshJ
- Nickname: Joshua
Jonathan I am not so read up on the pick-ups but in SA nissan only replaced the 4.2 with the 3.0CRD in 2014. That 2012 model may be an import. The 3.0DI pickups ran in Aus long before the CRD ones. The 2012 one is however defenitly a Di. What the story of that bakkie is I dont know.
Joshua
Joshua
- JoshJ
- Nickname: Joshua
That is the correct asumption
Joshua
Joshua
- JoshJ
- Nickname: Joshua
Another way to check is. On the crd the intercooler intake pipe is on the passanger side. The outlet is on the driver side. On the di they are both on the passanger side. The tappet cover on the crd is flat and more sqaure. The tappet cover on the di is higher and rounder.
Joshua
Joshua
