Hi ricster, it is the bushes where the sway bar connects to the axle. I have replace my standard shocks and now there seems to be movement of the sway bar. The bushes are slightly warn and thus the bar moves up and down.
When driving over even rough tar surfaces with small bumps it seems that I get a rapid hoping motion in the suspension. I hope this is the solution?
G-Man, Nissan only sells the entire sway bar unit and not the bushes separately, or do you know an agent who does?
Can't someone machine these locally?
Panhard rod and other bushes
- Has thanked: 1134 times
- Been thanked: 1044 times
Re: Panhard rod and other bushes
Ruben, you're barking up the wrong tree I'm afraid. Sway bar bushes can't do what you describe.Ruben wrote:Hi ricster, it is the bushes where the sway bar connects to the axle. I have replace my standard shocks and now there seems to be movement of the sway bar. The bushes are slightly warn and thus the bar moves up and down.
Sounds to me like shocks or shock mounting rubbers.
- Dungbeetle
- Full Name: Rudolf
- Nickname: Dungbeetle
- Home Town: Ellisras
- Has thanked: 69 times
- Been thanked: 70 times
G-MAN wrote:Been there done that!![]()
Only bushes you replace your Patrol's bushes with is Genuine Nissan agents bushes, last longest.
1 - Panhard bushes wear out prematurely if your steering damper is kaput, those little wobbles at 80-90 kph takes it's toll.
2 - Only replace bushes with the real Nissan part
3 - Apparently for the Y60 you can buy bushes loose from Nissan, but for Y61 only the whole Panhard, not sure of the rest of the suspension stuff
But:
My Patrollie 4.2D(onkey) has done 729 613 km and I have only replaced the Steering Damper x 2, Panhard x2, No/nothing/zip else all still seems fairly OK (touch wood)
I sometimes do notice slight jumping on uneven tar - I am told that can be the bushes of the trailing arms...makes sense
2012 NP300 DC - platkar
- David
- Full Name: David Prinsloo
- Nickname: David
- Home Town: Stellenbosch
- Been thanked: 49 times
On the Y61 the agents only sell/list complete kits but most of it is the same as on the Y60. If you can get a Y60 serial number you should be able to source the individual parts.
I replaced my panhard bushes some time ago - here's the part numbers:
Lower Bush (all models) 55135 01J01
Upper Bush (std type) 55135 01J10
Upper Bush (Balljoint Type) 40110 VC000
Jiss Ruben .. 'k weet Mirrelburg is 'n entjie maar as jy kan .. SYD's Suspencions in Pretoria Wes [Vom Hagen straat ek dink] hulle maak baie mooi daai rubber oor .. Lobo gedoen 6 jaar geldede en hy nog n heppie chappie
TERLOOPOS :: ek nodig shocks .. met lekker laaaang trewwil, vir ou Lobo
