Please explain how the gearbox work on my tiptronic
Driving, recovery & more
graham1
Full Name: graham robertson
Nickname: graham1
Home Town: Harties
Has thanked: 9 times
Been thanked: 100 times
Re: Please explain how the gearbox work on my tiptronic
Post by graham1 »
Hi guys, a quick question here, I've never used an automatic off road before - with my 4.8 auto, if I'm descending a very steep slope, do I use the tiptronic to select 1st and will it keep it in 1st for the whole descent?
Chris Skinner
Full Name: Chris Skinner
Nickname: Chris
Has thanked: 10 times
Been thanked: 53 times
Post by Chris Skinner »
Hi Graham - yes it will.
The gear you select on Tiptronic is the highest it will change to ie if you select 3 then it uses 1,2 and top is 3. nIf you select 1, then it stays in 1!
By the way - there is a small and easy mod one can do to be able to continue using speed control when you click into Tipronic and visa versa....
Johannes van die See
Full Name: Johannes van der Merwe
Nickname: Johannes van die See
Home Town: Langebaan
Current 4x4: 2008 - 4.8 GRX Patrol
Been thanked: 4 times
Post by Johannes van die See »
Chris Skinner wrote:By the way - there is a small and easy mod one can do to be able to continue using speed control when you click into Tipronic and visa versa....
Hi Chris, can you share the info please.
http://www.goblacksam.com
Langebaan Lagoon & Deep Sea Fishing Charters
DawidT
Full Name: Dawid Taljaard
Nickname: Dawid
Home Town: Witbank
Nissan Patrol 4.2l GQ
Volkswagen Caravelle 4 Motion
2018 Toyota Landcruiser V8 DC
Has thanked: 5 times
Been thanked: 30 times
Post by DawidT »
I did the mod on my Patrol and it works well. Here is the file - pics and description (Hope it attached and you can read it). If not, give me your e-mail address and I will forward it to you.
Patrol speed control mod.xlsx
(697.57 KiB) Downloaded 371 times
Thanks, got it
graham1
Nickname: graham1
Home Town: Harties
Post by graham1 »
Chris Skinner wrote:Hi Graham - yes it will.
Great. thanks Chris!
I'll test this out on the weekend.
Mal Hannes
Full Name: Hannes Wessels
Nickname: Hannes
Home Town: Roodepoort
Has thanked: 26 times
Been thanked: 26 times
Post by Mal Hannes »
I learnt about the lock up this weekend on a trail.
My previous Auto had less tc slippage than the Patrol so it was fine to just point and shoot in Auto.
With the Patrol I found that for any slippery surface you must go to manual.
It was a very interesting experience to just get stuck on a slippery hill and not go anywhere. once I engaged 2nd gear I made a lot more progress and in first gear just idled up a steep slippery gravel hill.
lesson learnt.
Return to “26. Techniques”
