Steering Knock
Unkredible
Full Name: Bruce Williamson
Nickname: Unkredible
Home Town: Rivonia
Home Language: E
Has thanked: 27 times
Been thanked: 24 times
Steering Knock
Post by Unkredible »
Hi All,
I have a strange knocking sound originating from the front wheels, particularly when reversing and turning / when turning the steering wheel whilst going slowly. Wheel bearings seem ok, have checked wheel nuts, and can't find anything loose with tie rods etc. I am thinking it may be Kingpin bearings that are stuffed...
Who is the go to "Expert" in Gauteng who can diagnose and repair this?
Bruce
285x75x16 MT
DC-DC Charger
Steele
Full Name: Gareth Steele
Nickname: Steel
Home Town: Jhb
Has thanked: 92 times
Been thanked: 62 times
Re: Steering Knock
Post by Steele »
I would take it to Ant or Michael. Ant is probably closer to you.
https://www.patrol4x4.co.za/viewtopic.p ... cw#p100397
Cheers, Gareth
Spike
Full Name: Spike Pretorius
Nickname: Spike
Home Town: Milnerton
Home Language: Sleg soutpiel
Has thanked: 77 times
Been thanked: 87 times
Re: Steering Knock
Post by Spike »
R5-00 bet it's the auto locking hubs messing around. Half-hour job to open and modify it. Quick permanent fix
:oldtimer:
Sardonic Fattist
Re: Steering Knock
jip Ant is closer to you its not perhaps the stopper rubbing against the end?
Unkredible
Home Town: Rivonia
Home Language: E
Re: Steering Knock
I dont think so - not necessarily happening at full lock. I suspect it could be the Auto Locking hubs playing up or something like that...
285x75x16 MT
DC-DC Charger
Re: Steering Knock
ok have the same on my frankestein s4 will give you feedback soon
AndriesS
Full Name: Andries
Nickname: None
Home Town: Pretoorsdorp
Has thanked: 28 times
Been thanked: 38 times
Re: Steering Knock
Post by AndriesS »
knock on both wheels, or one side , left and right turn or only one side, while standing or moving , if sound from right - can it be from play somewhere steering wheel shaft .
Russ Kellermann
Full Name: Russell Kellermann
Nickname: Russell Kellermann
2005 Patrol 4.2TD Wagon
Re: Steering Knock
Post by Russ Kellermann »
Can easily be the radius arm bushes. They click/clack if they worn when turning slowly, and reversing too, as they load/unload. check them for wear.
Unkredible
Home Town: Rivonia
Home Language: E
Re: Steering Knock
Been playing around with it. Knocking while stationary too. Will put it up on axle stands again and do more digging...
285x75x16 MT
DC-DC Charger
Russ Kellermann
Re: Steering Knock
get a pry-bar onto all those links (control arms, drag link, tie road, panhard rod, etc etc) and work them to see if there's play or wear.
