TB 42 fuel tank pressure
Relating to fuel tanks, long range, fuel type, fuel filters and other fuel related queries
Russtic
Junior Member
Junior Member
Full Name: Russell Furlong
Nickname: Russell Furlong
Current 4x4: Y60 petrol
Post by Russtic »
Good afternoon and seasons greetings to all.
I opened my fuel filler cap today and was greeted by a serious "whoosh!" The fuel tank had some serious pressure in it, took a few seconds for the pressure to drop.
Is this normal, could it be the cause of my missing and the engine not wanting to rev?
Has thanked: 1136 times
Been thanked: 1047 times
Re: TB 42 fuel tank pressure
Definitely not normal or correct, and could cause issues (although normally it's vacuum that causes problems, not positive pressure).
In the wheel arch under the filler there is a flimsy plastic cover held on with 3-4 screws. Remove that (can be done without removing the wheel, you just need a stubby screwdiver). Under that you eill find the breather. Make sure it's open , clean and working.
Return to “11b. Fuel Related”
