The Prepper Wagon
Dungbeetle
Full Name: Rudolf
Nickname: Dungbeetle
Home Town: Ellisras
Current 4x4: 2000 Patrol 4.2GL Wagon old and wise at 851 000 km
2014 Patrol 3.0GL CRD reaching puberty at 113 000 km
Home Language: Afr
Has thanked: 26 times
Been thanked: 39 times
Re: The Prepper Wagon
Post by Dungbeetle »
Backlash and or axle play...
i would not be bothered with a Patrol. Mine is heading for 900 000 km with all components still the original parts. (except wheel bearings). Patrols have very large diameter drive line and diff internals and a little wear will show more play at the wheels than other similar vehicles?
Also, in 20 years and all that distance I have changed the diff and gearbox oil only twice - obviously when wheel bearing replacement was to be done. Never had bearing failure, only precautionary maintenance.
I should add:
I noticed much more rolling with the hand brake engaged on the old 4.2D than on my newer CRD
2000 Patrol GL 4.2D - Still strong after
Eight Hundred and fifty and counting THOUSAND KILOMEEEEEEEEEEEEEETERRRRRRRRRRRRRRRRSSSSSSSSSSSSS
