Error Code P1805
JTEC
Full Name: Jade Dafel
Nickname: JTEC
Home Town: Somerset West
Has thanked: 164 times
Been thanked: 64 times
Error Code P1805
Post by JTEC »
Hey Guys
Has anyone ever experience the error code P1805? From googling it seems its the Brake Light Switch under the brake pedal. The strange thing is that it paired with my throttle position sensor error caused by a leak in one of my vacuum lines. I have solved that problem now but cant seem to solve the P1805 ? :thumbdown:
GQ Patrol TD42
ex GU Patrol TB48
Bokdrol Adventures
JTEC
Nickname: JTEC
Re: Error Code P1805
Post by JTEC »
So an update on this. I managed to replace the brake light switch with a generic part from Midas for about R70.
The OEM nissan one looks something like this.
The generic one looks like this
Its a straight swop, the only difference is there is no plug housing on the generic and the female plug from the harness just slots over into place.
Something I want to point out, when I connected the new one and took it for a test drive the car felt terribly down on power and struggled to accelerate. I noticed that the brake lamps were still on without the brakes applied so I needed to adjusted the switch to the correct position so that it was not activated when no brakes were applied. Test driving after, the power was back to normal and accelerated as it should. This proves that the 4.8 auto ecu reduces the engine power when brakes are applied, something I had read about but wasn't sure.
GQ Patrol TD42
ex GU Patrol TB48
Bokdrol Adventures
Jip had the same issue after 3 pirate switches i paid 250 for the nissan one and i was sorted . I by passed it in moz and drove home like that ...not lekke if power doesn't get less :salute:
Thanx for the useful feedback Jade :bravo:
