JTECs Patrol Progression( UPDATE on PG 6 )
JTEC
Full Name: Jade Dafel
Nickname: JTEC
Home Town: Somerset West
Has thanked: 146 times
Been thanked: 54 times
Re: JTECs Patrol Progression
Post by JTEC »
Another quick update.
Painted the roof rack black as I felt it would look better with the trims. Used Duram 88 recommended by Tinus. What an excellent product. Easy to apply and settles to a nice matt finish. Feels very durable but will have to see.
Also tested and fit the Front Runner jerry can mounts in position.
Picked up these seat organisers from Camp&Climb, very cool and well priced. Im sure the kids will eventually fill it with toys :biggrin:
I then tried re positioning the steering wheel which I thought was off center. After adjusting it 3 times I confirmed that it was actually in the center before, It would just sit skew when driving as there was too much play in the steering. I then adjust the steering box by 1/4 turn and this has made it much better. Steering sensitivity is better and therefore the left pull compensation is not so bad. feels good now.
If anyone wanted to see, heres the clockspring behind the wheel
GQ Patrol TD42
ex GU Patrol TB48
Bokdrol Adventures
Bre
Full Name: Brent Harris
Nickname: Bre
Home Town: Bellville
Has thanked: 52 times
Been thanked: 33 times
Post by Bre »
Looking good Jade. :thumbup:
Has thanked: 183 times
Been thanked: 211 times
:coolphotos:
The black roofrack is an improvement!
:thumbup:
IanT
Full Name: Ian Temperley
2008 4.8 GRX Umkombe
Been thanked: 91 times
Post by IanT »
Hay Jade! Are you copying me :surprised: Same colour bumpers! same colour fender flares! same seat covers! Same colour Roof Rack :rolling: :rolling:
JTEC
Nickname: JTEC
Post by JTEC »
IanT wrote:
17 Jul 2019 12:11
:biggrin: :redface: Imitation is the sincerest form of flattery :wink:
You made this beast look good, im just fine tuning now :lol:
GQ Patrol TD42
ex GU Patrol TB48
Bokdrol Adventures
JTEC
Nickname: JTEC
Post by JTEC »
Some small updates ~
Done a full service,
Oil - Delo 400 15w-40
GUD Oil Filter Z226
Nissan OEM Air Filter
Plugs NGK Platinum PLFR6A-11
Replaced Fuel pump with and aftermarket Electro Part 3.8Bar pump(Very Cheap) Would like to change to a Walbro hi flow at a later stage
GUD E15 Fuel Filter
After the service I picked up a missfire which I thought couldve been a vacuum leak as I had one previously. After checking all the pipes and finding nothing I started researching what else could cause the missfire and with lots of goooogling :typing: and advice from fellow Patrol owners QQQ I put it down to a faulty coil pack. When changing the plugs I had noticed that No.1 Cylinder coil pack looked different to the others, I found that it was the coil pack from the VQ35de (350z V6) and that the spark plug in that cylinder was also the incorrect spec :doh: So I decided because the vehicle has high millage and I intend on overlanding that I will replace all coil packs at once. This obviously is an expensive exercise :signhere: so I done a little further digging and found that the TB48 shares the same coil pack as the VK45de found in some of the Infinity vehicles. I managed to find a full set of 8 new aftermarket units for about a quarter of the price of 6 new OEM from the USofA. I know they wont last as long as OEM but we can only tell how long by testing. At that price I can change them 4 times if need and I also have 2 spare. Lets see how they go :shifty:
After changing them I set the timing at +10deg and then done an Idle Air relearn. It is now driving silky smooth with nice power :rock:
New coil alongside the old OEM
While changing the fuel pump I came across a very very dirty fuel pump cover. I recommend checking out yours if youve done some muddy offroading before.
With some degreaser and a hose pipe I gave it a good scrub.
And then lastly I sold off the OEM rims and picked up a set of Dynamic Steel fake beadlocks. When I eventually get round to running 35 muds ill change them to a proper set. For now I think it looks really cool :cool:
Next up on this list of items:
Brake disks and pads
Front and rear diff service
Transfer case service
Bilstein Shocks and coils 3"lift
Tentco Awning
Finish up storage system
Electrical wall
Till the next update :cya:
GQ Patrol TD42
ex GU Patrol TB48
Bokdrol Adventures
Has thanked: 781 times
Been thanked: 185 times
Looking good Jade! Thanx for the update.
Flickr: http://www.flickr.com/photos/jhemurray/sets/
Nissan KingCab
Full Name: Danie
Nickname: Danie
Home Town: Madibeng
Home Language: Afr
Has thanked: 31 times
Been thanked: 22 times
Post by Nissan KingCab »
Thanx for keeping us up to date on your Patrol, it's nice to see each owner giving their Patrol their own personality!
Has thanked: 473 times
Been thanked: 421 times
Jade, for the brake pads and rotors (disks) I can definitely recommend Marinus (Terrain Tamer 4x4) here on the forum. See here... viewtopic.php?f=47&t=8196
Bre
Nickname: Bre
Post by Bre »
Looking good Jade :thumbup:
