USB music player
Tunja
Full Name: Ernest Tunnah
Nickname: Tunja
Home Town: Swakopmund
Has thanked: 9 times
Been thanked: 18 times
USB music player
Post by Tunja »
I'm picking up the Troll next week and heading back to CT. I've just noticed the music player is an CD type with no USB or Aux port that I can see.
I need some music for the long road... I have USB full of decent driving music sooo any advice where I can get a USB unit fitted in the Roodeport area like in a hr or two on 18th around midday?
Will worry about speakers later but cant drive +-1500kms without sound - any decent places there?
Even a screen unit with a camera (to be fitted later) would do.
Speed of installation is of the essence here :biggrin:
Thanx
Patrol JVC.JPG (48.11 KiB) Viewed 8624 times
Re: USB music player
Speak to anthony here mabe he can help
David
Full Name: David Prinsloo
Nickname: David
Home Town: Stellenbosch
Been thanked: 49 times
Post by David »
Otherwise just buy an FM Modulator for the trip and sort your head unit out when you get back home. :mytwocents:
They normally take a USB at the bottom.
Been thanked: 473 times
Yeah, I kind of agree with David. Don't rush out to buy the first headunit you see. Good sound is paramount, and a quick R99 for the trip will be far better than quickly buying a headunit that is not going to serve you well.
Tunja
Nickname: Tunja
Post by Tunja »
Anthony, do you have anything decent that can be fitted in an hour or so? I can always sort out decent speakers and camera at a later stage. If not i will go with the converter.
Thanx Guys I didn't think of a converter. Will have a look - it certainly fills the "time limit" scenario. :goodpost:
mvcoller
Full Name: Malcolm van Coller
Nickname: mvcoller
1998 4.5 Patrol SGL
Home Language: Afr & Eng
Has thanked: 41 times
Been thanked: 186 times
Post by mvcoller »
https://www.geewiz.co.za/car-accessorie ... hOEALw_wcB
https://www.makro.co.za/makstorefront/m ... 0221310_EA
Same as the one above mentioned by David, used one for many years in my Terrano that did not have a SD Card or USB slot. The only problem while travelling was as you come into a new FM transmitter area, the radio may pick up a new station on the wavelength you have set the unit up on. A quick adjustment and you are OK again. It even displays the song title as it is playing!!! Some Martix Computer Shops sell them as well.
Cheap and nasty, but for around R100 to R130, it works fine, sets up in a minute and you it into another car (for the son or daughter) at the drop of a hat.
Then you get the Bluetooth ones for slightly more, that work as a handsfree kit for you phone and can play music from your phone as well:
https://www.takealot.com/bluetooth-car- ... atureOffer
Or the type that plugs into your phone and will play music from your phone on FM
https://www.itoys.co.za/fm-radio-transmitter
AND last but not least, pair the phone and the radio via Bluetooth and use your phone as a Music Player - That will cost ZERO and set up in minutes (if it is a Bluetooth radio)
I fitted this one in my Patrol (without GPS) because I run 2 GPS's in my Patrol already
https://www.autostyle.co.za/product/tar ... vd-system/
and this one in my Pathfinder (with GPS)
https://www.autostyle.co.za/product/tar ... avigation/
I found them excellent and only have small issues sometimes, such as that when I turn the car off, it would not always turn on automatically when I restart the car. At other times it does. Not a big problem, when is does not turn on automatically, I do it manually...
Very good value for money and works with the steering buttons... and took my fitment centre about 2 to 3 hours to install including fitting the reverse camera.
ra_01
Full Name: Rahul
Nickname: Rahul
Current 4x4: Patrol 4.8 2016
Has thanked: 23 times
Been thanked: 60 times
Post by ra_01 »
I would go for one of these. Bit expensive but I would invest in a descent headhunt if I am replacing the current one.
Future proof sort of..
https://www.rivoniacarsound.co.za/produ ... av-ax5000/
Rahul
Current Straight 6 :wink:
Tunja
Nickname: Tunja
Post by Tunja »
Thanks Malcolm, I like the unit fitted to your patrol. Will probably buy something like that for my daughter's swb Mitsu she tows her horse box with, doesn't need satnav but needs a rear camera.
I'm thinking I don't really have time to fit a decent unit unless Anthony can wave a magic wand somehow, so will have to go with anything that will play from my USB for the time being.
Rahul, that unit looks good and is a lot cheaper than the Caska I fitted to my other 4x4.... which doesn't seem to like Mp4 music files, keeps going into Video mode and playing them but I can't get back out of video mode and have to remove the USB just to play other music.. bit frustrating, probably need to convert them to Mp3
mvcoller
Nickname: mvcoller
1998 4.5 Patrol SGL
Post by mvcoller »
Will this work with your steering wheel buttons?
Ernest - Bring that USB with sound to oompie -- I transfer the MP3 to CD or DVD for you , and then you mos have music virri pad .. neh?
Return to “13b. Audio Systems”
