Replacement Hub Cover
- georgeb
- Full Name: George Brittnell
- Nickname: georgeb
- Home Town: Hartbeespoort
- Has thanked: 98 times
Dagsê almal
Enige idee waar ek kan aanklop vir 'n "cover" - myne lê iewers in Namibië?
- Hub
- DSC_0121.jpg (1.47 MiB) Viewed 5072 times
Groete/Regards,
George Brittnell
George Brittnell
- Full Name: HS
- Nickname: Picasso
- Current 4x4: Nissan Patrol
- Has thanked: 10 times
- Been thanked: 44 times
Re: Replacement Hub Cover
Hallo George
I am not really giving you a solution to the problem, but some pointers:
These are the 16 inch rims / 4.8 pre-face lift.
I think that the 4.5 and the 2005/4.8 post face lift Center hubs caps are different.
So I guess those once (yours) are quite scares.
What I would suggest is to take a photo of one of the remaining center hubs inside and outside and add it to your post.
David Volschenk has a 2003/4 4.8 which had the same rims. However I doubt that the rims or center-caps are still available. Nevertheless give him a call on 0834991588.
Than there is Johns Engine and Gearbox in Boxburg which is currently stripping a 98 4.5 . Wheels and center caps are still there , however they might want to sell the rims and center caps together ? Should the 4.5 Center caps fit than this could be an option.
Tel. 011 892 4746
Third option is to find something on this forum.
The last and most expensive options is obviously the dealers.
After a long search I finally gave up and bought a replacement cap for mine at the beginning of this year................ was around 950 Rand
Good Luck
Henning
Tel. 011 892 4746
Good Luck
Henning
- NMAD
- Full Name: noel
- Nickname: happy
- Home Town: C
- Current 4x4: 20
- Home Language: E
- Has thanked: 51 times
- Been thanked: 10 times
The covers are the same on the 16 inch grx mags and the 17 inch grx mags as I have both sets. I actually bought that 16 inch set from David a while back.
I have extra covers but I am in capetown
- georgeb
- Nickname: georgeb
Afternoon Noel
Please PM me - get the following when I PM you:
"The requested users to be added do not exist."
Groete/Regards,
George Brittnell
George Brittnell
- Full Name: Errol Wilken
- Nickname: Wilkie
- Has thanked: 69 times
- Been thanked: 92 times
you must enter his user name NMAD....... I had the same problem when putting full name ingeorgeb wrote:Afternoon Noel
- georgeb
- Nickname: georgeb
you must enter his user name NMAD....... [/quote]Wilkie wrote:
Yebo Wilkie
What I am doing is to click on his NMAD username in this thread and that takes me to a page where I can send a PM from and from there it brakes when sending.
- NMAD PM
- Untitled.png (361.81 KiB) Viewed 5049 times
Groete/Regards,
George Brittnell
George Brittnell
- georgeb
- Nickname: georgeb
Started a new PM from my Messages and it seems to be successfully sent.
Groete/Regards,
George Brittnell
George Brittnell
- Full Name: andre durand
- Nickname: leeuloop
- Home Town: Alberton
- Current 4x4: PATHFINDER
- Home Language: afr
- Been thanked: 37 times
George ek het een wat nog van my Hardbody dae af kom as dit die selfde is is hy joune
Andre Durand
Nissan Hardbody 3.3 sold
Nissan patrol 4.5 sold
Nissan parthfinder 2,5 sold
Nissan navara 4l v6 4x4
Ek het ook een ......wat aandag nodig het sal hom die 10de saam vat....het laas 5 gekoop vir 200 durrum elk in uae
