Windscreen replacement - your advice plse
HermPatrol
Full Name: Herman Smith
Nickname: Herman
Current 4x4: Patrol 4.8 GRX - Vellies
Post by HermPatrol »
Have to replace my front window / windscreen as a few stones ensured cracks throughout.
In previous posts was it mentioned that the people doing the replacement needs to be watched that they do not brake any clips, not sure where these are and should one not rather buy new set from dealers to be installed at same time with new glass? :think:
In addition where would you recommend in Pretoria do I take the Patrol for this, anyone out there which I can trust to work on the Patrol?
As always, your views and feedback is much appreciated
Herman
AndriesS
Full Name: Andries
Nickname: None
Home Town: Pretoorsdorp
Has thanked: 28 times
Been thanked: 38 times
Re: Windscreen replacement - your advise plse
Post by AndriesS »
I think Mr Skinner suggested some of the independent installers, not PG etc. Their prices at R1250 is also more reasonable.
They main clips to look out for are those used to attach the vent panel (between the bonnet and windscreen) They will most likely break them and if they are not put back properly and sealed you will have a leak in the passenger footwell. I'm actually thinking of removing the panel myself to prevent frustration.
Second issue could be the window surround, would be interesting if most places replace it or not. Don't have answers on it. I think Ricster mentioned his is loose
yip... my rubber surround that clips into the rubber around the glass itself is not fitting properly due to some of that black snotty stuff to glues the glass to the body getting into the grove that holds the outer rubber surround. Most places like National Auto Glass etc can do it without any issue but I seem to battle to get the windscreen with the blue sun tint on the top. Mine now also has a crack after Saturday AAWDC fun day. I hear the stone hit the windscreen just as I got onto the main road, and by the time I got home ( only noticed the run the next morning) it had a horizontal run dipping down to the side.
So I will have to get a new windscreen !! :confused: :confused:
Chris Skinner
Full Name: Chris Skinner
Nickname: Chris
Has thanked: 10 times
Been thanked: 53 times
Post by Chris Skinner »
I went to Govcon in Pta north, voortrekker road - good service and under R1000...
Ek het myne by BSG in Boksburg vir R800-00 laat opsit.
Re: Windscreen replacement - your advice plse
Main thing though is to ensure SABS approved, I assume insurance companies will have something to say if not :think: :think: :think:
andredurand
Full Name: andre durand
Nickname: leeuloop
Current 4x4: PATHFINDER
Home Language: afr
Been thanked: 37 times
Post by andredurand »
Cedric ek het n kontak in Alberton as jy belang stel
Andre Durand
Nissan Hardbody 3.3 sold
Nissan patrol 4.5 sold
Nissan parthfinder 2,5 sold
Nissan navara 4l v6 4x4
HermPatrol
Nickname: Herman
Thx for all the replies
Reenen
Full Name: Reenen Kritzinger
Nickname: Reenen
Home Town: Greyton
Current 4x4: SFA Hardbody
4.8 GRX
V9X Navara
Safari Stasiewa
Safari Pickup
Safari stasiewa
88 Isuzu RD28 Nissan
1978 300D Merc RD28 Nissan
Been thanked: 126 times
Post by Reenen »
My safari pick up wat ek opbou kort n voorruit. Waar en by wie in weskaap kan ek laat insit? Hier by ons op dorp is n PG glass. Dit lyk na n heel eenvoudige jobbie op die safaries.
Has thanked: 61 times
Been thanked: 258 times
Hi Reenen
Weet net by PG en Autoglass betaal mens 'n fortuin. Dit is versekerings premie pryse.
Mens behoort in die Kaap net soos hier in Gauteng onafhankelijke ouens te kan vind wat die selfde gehalte werk doe met SABS ruite. Ek ken net nie een in daardie geweste wat ek kan aanbeveel nie.
